Rebuild Optispark (possible?)
Old 01-14-2017, 02:10 PM
charliet615
charliet615's Avatar
Default Rebuild Optispark (possible?)
I have an extra Optispark that I want to rebuild. It's for a 93 LT1 and I was wondering if anyone knows where I can purchase the O ring, bearing and dist cap gasket. I have a new cap/rotor and this one is vented. Thanks Guys........Any help is appreciated.....
Old 01-14-2017, 07:06 PM
1993C4LT1
1993C4LT1's Avatar
You can, but not worth rebuilding it if the sensor in it is bad. Not sure where you could get those parts, but I would ask any company that sales optis.
charliet615 (01-15-2017)
Old 01-14-2017, 08:04 PM
charliet615
I believe that the sensor is good and a Mitsubishi. Thanks, anyone else?
Old 01-15-2017, 09:44 AM
RollaMo-LT4
RollaMo-LT4's Avatar
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17-'19-'20-'21-'22-'23
Originally Posted by seabright
technology. I would assume that by now, every original opti placed in service ('92-'96) has failed (?).
Really?
My '96 LT4 with approx. 124K miles is running just fine on the factory original Opti.
Old 01-15-2017, 10:03 AM
ddahlgren
ddahlgren's Avatar
Probably somewhere like McMaster Carr or MSC to name a few. Just buy them as a generic part. If the cap gasket is paper just make one out of gasket material. For the bearing I would stick with SK or Timkin.
Old 01-15-2017, 10:09 PM
GaryDoug
GaryDoug's Avatar
You can check the Opti for electrical operation as follows: Unplug the cable going to the Opti in the engine. Plug it into the Opti to test. Have someone watch the tachometer with the ignition on while you spin the Opti shaft counterclockwise. If the electronics, including the sensor, is working the tach needle will rise up according to how fast the shaft is spun. I assume that electronic display tachs will do similarly. Probably a good idea to pull the injector fuse(s) first.
Old 12-01-2020, 02:52 AM
threefiveleven
2nd Gear
threefiveleven's Avatar
Late to this party, but wanted to ask if anyone did in fact try out the sac city opti? Now years later how's it going?
I've used ACDelco for my first 2 replacements. Just rolled over 200,000 miles and its time for another.
Old 12-01-2020, 07:46 AM
Charsel
Charsel's Avatar
Ihave a saccity opti for 3 yrs now in my '95, after having 2 AC Delco units fail in 18 months. Very happy with saccity, easy to email/call with questions.
Old 12-01-2020, 08:49 AM
rhandle
rhandle's Avatar
If anyone is looking for Mitsubishi sensor,go to a junkyard. There are plenty of low mile Optis there with low miles. You just need a new cap and rotor. IF ANYONE WOULD ANSWER THE QUESTION ,I was also wondering where to buy the gaskets
Old 12-01-2020, 01:40 PM
threefiveleven
2nd Gear
That's good news! I think this is the route I'm going. Thanks!
Old 12-01-2020, 02:42 PM
Whaleman
Whaleman's Avatar
Look up optidoctor on here or ebay. He rebuilds these as a business and has all the parts and gaskets. Dan
rhandle (12-05-2020)
To Rebuild Optispark (possible?)
Quick Reply: Rebuild Optispark (possible?)
