88 headlight schematic
Old 03-26-2017, 08:58 PM
TopGunn
TopGunn's Avatar
Default 88 headlight schematic
Does anyone have a schematic for the headlight actuation circuit for an 88 they could share? The headlights go up OK but the drivers side will not go down. Verified the motor is good by applying 12v and it goes down then but will not go down when hooked up to the system.
Thank you
Old 03-26-2017, 10:01 PM
GREGGPENN
GREGGPENN's Avatar
C4 of Year Winner (appearance mods) 2019
Didn't blow up and read this link but I'm guessing it's what you want....
https://www.corvetteforum.com/forums...post1587667181
TopGunn (03-27-2017)
Old 03-27-2017, 01:11 AM
Cliff Harris
Cliff Harris's Avatar
I think the headlight motors being changed in 1988 would also apply to the wiring associated with them. In other words, a diagram from an earlier year wouldn't apply.
The following 2 users liked this post by Cliff Harris:
GREGGPENN (03-28-2017), TopGunn (03-27-2017)
Old 03-27-2017, 07:42 AM
cdm747
Support Corvetteforum!
cdm747's Avatar
St. Jude Donor '17-'18-'19-'20-'21-'22
I have attached the wiring diagrams and guides from my 88 FSM.
good luck.
Old 03-27-2017, 08:23 AM
TopGunn
TopGunn's Avatar
good luck.
Excellent, many thanks.
Thanks to others for the replies.
Bill
Old 03-28-2017, 03:26 AM
GREGGPENN
GREGGPENN's Avatar
I remembered the gearing had changed but hoped the relays and technique for rotating the lights had remained the same.
Old 03-28-2017, 01:42 PM
Hot Rod Roy
Hot Rod Roy's Avatar
Wrong! They are entirely different. The relays for actuating the headlight motors were eliminated in '88, and the motors and geartrain are entirely different. '88 is when the pesky "bushings" were added to the motors, which occasionally need to be replaced.
To identify: the '84 - '87 headlight motors have the manual actuation ***** on the bottom of the motors, and the '88 - '94 motors have the manual actuation **** on the top.
Old 03-28-2017, 06:50 PM
GREGGPENN
GREGGPENN's Avatar
Yeah...I've replaced those nylon gears once. Boy, was THAT fun!
Over time, I had gotten an incorrect impression about the existence of relays on my 89. I thought there were 2...one for each side. I even thought they were on the DS inner wheel well. Now, I'm thinking at least one is for the radiator fan.
Looked at the PDF (linked a couple posts up). Says there is a solid-state "Headlight control unit"? I never noticed that before..or where it's located. Guess I'll have to check the component location diagrams next time I have my FSM out.
To 88 headlight schematic
Quick Reply: 88 headlight schematic
