[Early C4 AC/Heater Poll]
Re: [Early C4 AC/Heater Poll] (Wheelman)
What problems are you having? Maybe someone else had the same thing happen to them and could suggest what needs to be done to fix it.
My air mixture module arm only goes one way (To heat). I placed the module on A/C so I get no heat right now. (I can live that way)
I must be a programmer problem... :D. I'll get to it sooner or later...
Location: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Re: [Early C4 AC/Heater Poll] (Coupe89)
Are you saying the slider is jammed? They are cable actuated, and get sticky over time. Pull the console plastic and the stereo, then you can access the AC/heater controls.
Re: [Early C4 AC/Heater Poll] (CentralCoaster)
A/C leaked out in August. Heater core let loose in Sept. Currently, no climate control at all.
Just had the AC in my 90 converted from R-12 to R-134. Had to replace the dryer and a couple of lines, but everything else is still in good shape.
Mark
:cheers:
Mark
:cheers:
