SuperRam cable bracket question.
I am trying to put my Throttle/TV/Cruise cable bracketry on the supreram, and found the TV cable just does not seem to bend up enough to fit.
If I mount it into bracket, I can barely screw the bracket to the plenum, and the TV adjustor is hitting the plenum with 89 degree bend to clear it.. I don't know if this is 'safe'.
Anyone have pics of their drivers side superrams, and how they routed the TV cable?
Thanks in advance.
Thanks in advance.
Re: SuperRam cable bracket question. (corvette0096)
Hmmm... I did the same as you, but on mine it does not clear the plenum as yours does.. :eek:
Former Vendor
Re: SuperRam cable bracket question. (MrNuke)
MrNuke!
Mine did the same thing when I first got it. They sent you the wrong bracket as they did me too! I am 100% sure you are having the same problem as me. Call whoever you bought the SR from and tell them they sent you the wrong one. Tell them you want it next day delivery. They were very co-operative when I called, it was Jegs I got mine through.
Really makes you mad when you pay that kind of money and they send you the wrong equipment. :mad
Let me know how you make out. :cheers:
Former Vendor
The old one from the TPI stock plenum/setup will not work. Tried that too, when they send me the wrong one. The bolt holes are in different locations. :rolleyes:
SuperRam cable bracket question. (yoslambo1@cs.com)
gabe, sell the super ram & put a carb on it! :jester :p:
Re: SuperRam cable bracket question. (JD 90 383)
gabe, sell the super ram & put a carb on it! :jester :p: How did I know that was coming? :rolleyes: :rolleyes: :jester :lol:
Re: SuperRam cable bracket question. (yoslambo1@cs.com)
Eric,
Hmm how shall I possibly START rebutting your remarks...... :hat
1....I'd like to have an EASY starting engine int he cold NE weather.
2....I'd like to get better than 12MPG on the highway.
3....No vapor lock.
4....I'd like to be able to pass emissions.
5....I LIKE my low end Torque.
6....Don't have to worry about jetting issues. (just tune the computer)
:jester
Ohh yea, so you gonna be the waxer president, or just a member this year?
:steering:
3....No vapor lock.
:jester
:steering:
Eric,
3....No vapor lock.
:jester
:steering:
3....No vapor lock.
:jester
:steering:
[Modified by yoslambo1@cs.com, 2:26 PM 2/25/2003]
Heheh I know. I had JD here and we were bustin your bollox..
I am actually happy with the setup. The Superram itself is a great piece of design. The holes and bolts all fit perfectly (although due to .. ahem... user error 4 were a PITA). Gaskets fit perfectly, etc etc.. I can have the plenum itself on and off within 30 minutes now.. Woohoo... :conehead
I got mine from LPE, I think I still have it somewhere if you need it.
