Prestone or GM orange coolant?
Old 04-17-2003, 10:58 AM
Bluewasp
Bluewasp's Avatar
NoVa Events Coordinator
St. Jude Donor '14
Default Prestone or GM orange coolant?
EDIT: Prestone orange or GM orange (dex-cool)
How many gallons would I have to buy for 50/50 mix?
[Modified by Bluewasp, 12:29 PM 4/17/2003]
Old 04-17-2003, 11:26 AM
87SAM
87SAM's Avatar
Default Re: Prestone or GM orange coolant? (Bluewasp)
About 2 gallons. As far as the type, well that is another debate and can depend on your year. Sometime in the early 90's the factory started using the orange stuff...
Old 04-17-2003, 12:07 PM
H P Bushrod
Moderator
H P Bushrod's Avatar
CI 5-6-7-8-9-10-11-12 Veteran
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18-'19-'20-'21-'22-'23
Default Re: Prestone or GM orange coolant? (87SAM)
Sometime in the early 90's the factory started using the orange stuff...[/QUOTE]
Dex-Cool (the orange stuff) was factory filled on the 1996 Vettes ONLY. Stick with the green stuff for any other year Vette. :chevy
Old 04-17-2003, 12:19 PM
Bluewasp
Bluewasp's Avatar
St. Jude Donor '14
Default Re: Prestone or GM orange coolant? (H P Bushrod)
:) I know i need to use orange, and you can't mix etc.. etc... My question is should I use Prestone ORANGE or GM AC/DELCO Brand of coolant? The GM Dex-cool is 18 bucks a gallon here in Germany and the Prestone Dex-cool is 8 bucks. I was going to use the Prestone orange but wanted to check here first.
[Modified by Bluewasp, 1:06 PM 4/17/2003]
Old 04-17-2003, 01:03 PM
FrankLT4
FrankLT4's Avatar
If the Prestone says it is equivalent to Dexcool then I would use the Prestone. I use Havoline since it says it is equivalent and costs $6 at Walmart.
Old 04-17-2003, 04:01 PM
JasonL
JasonL's Avatar
Default Re: Prestone or GM orange coolant? (FrankLT4)
:iagree:
I use Havoline too. If it meets the GM spec, it should say so right on the label.
Old 04-17-2003, 04:17 PM
froggy47
froggy47's Avatar
Default Re: Prestone or GM orange coolant? (JasonL)
I used the orange Havoline, they have to certify it's equivalent. No problems here.Saved many $$$$$$$.
Old 04-17-2003, 04:22 PM
Goggles Pizano
Goggles Pizano's Avatar
Default Re: Prestone or GM orange coolant? (froggy47)
:iagree: :steering:
Old 04-17-2003, 04:29 PM
ZELLSLIFE
ZELLSLIFE's Avatar
I use the prestone orange in my 95 :yesnod:
Old 04-17-2003, 04:45 PM
myscx
myscx's Avatar
I use dexcool in my 90 :cheers:
Old 04-17-2003, 05:31 PM
sumoboy
sumoboy's Avatar
Make sure you mix 50/50 with distilled water.
Old 04-17-2003, 10:27 PM
Alex D
Alex D's Avatar
Default Re: Prestone or GM orange coolant? (sumoboy)
I got the Prestone mixed with the original DexCool half and half for two years now.......no problem at all......
To Prestone or GM orange coolant?
Quick Reply: Prestone or GM orange coolant?
