How do you adjust WOT shoft points for a 700R4?
I just had the transmission for my '91 rebuilt. Before it went in it would shift at 5500-5700 rpm. Now that I have it back it upshifts at 5000 rpm. How do I adjust the shift point back to 5500-5700 rpm?
Cruise-In II Veteran
Re: How do you adjust WOT shoft points for a 700R4? (newowner'91)
You need to change the springs & smaller weights (there are large & small weights) inside the governor.
You can get a B&M Governor Recalibration Kit for about $35 or so. A cheap (~$20) digital postal scale is helpful, one that measures to the nearest gram.
