Bad catalytic converter?
Old May 24, 2003 | 03:54 PM
Hall1836's Avatar
Hall1836
Default Bad catalytic converter?
What are the systomys of a bad catalytic converter? Do NOx go up on smog test, can it cause the engine speed to flucuate up and down?
Old May 24, 2003 | 04:02 PM
Z-PDX's Avatar
Z-PDX
Default Re: Bad catalytic converter?
The first thing to do is get under the car and bang on the cat with your fist.
If it sounds like its full of sand or rocks, it bad.
If it passes that test, it could be good OR bad.
Ain't diagnostics grand?
-Z
Old May 24, 2003 | 07:18 PM
IBEAM700's Avatar
IBEAM700
From: Looks like I picked the wrong week to stop sniffin glue Orlando
Default Re: Bad catalytic converter? (Z-PDX)
:iagree: but make sure tha Cat is cold first. :lol:
Old May 24, 2003 | 07:36 PM
MrNuke's Avatar
MrNuke
Default Re: Bad catalytic converter? (Hall1836)
I odn't knwo about exact NOx emissions, etc..
But when my cat was bad (FULLY bad).
The car ran like CRAP, always wanted to stall at idle,
and barely made it past 30mph even when 1/2 on the gas.
Felt mroe like a bad transmission than a cat. But it was tha cat.. Thank god.
Old May 24, 2003 | 08:45 PM
vader86's Avatar
vader86
If its clogged up, the car will run like sh** and there will be an abnormal amount of heat in the cabin.
To Bad catalytic converter?
