Factory alarm deactivation on an '85
Old 08-07-2003, 05:25 AM
mshay
mshay's Avatar
Default Factory alarm deactivation on an '85
How do I permanently deactivate the factory alarm. It seems to have a mind of its own lately and I plan to add an aftermarket alarm that will also control the power locks. Thanks
Old 08-07-2003, 07:40 AM
Bluevette85
Bluevette85's Avatar
Default Re: Factory alarm deactivation on an '85 (mshay)
The Theft Deterent Module (TDM) is located on the passenger side above the kick panel. It's hard to get at but has a connector you can disconnect.
Old 08-07-2003, 11:42 AM
mshay
mshay's Avatar
Default Re: Factory alarm deactivation on an '85 (Bluevette85)
Thanks. What does the module look like? Black plastic box? Any chance anybody has a picture?
Old 08-07-2003, 01:32 PM
carcruse
carcruse's Avatar
Did they move it after '84? For '84 it is behind the center information cluster(security, door ajar, etc.) next to the horn relay. There is also a 10 amp fuse back there going to the module.
Old 08-07-2003, 03:47 PM
DF
DF's Avatar
I could be mistaken but I think it is either a black plastic box or a grey metal one. It is bolted to the dash supports right behind the breadbox (the passanger side "Corvette" dash pad).
Old 08-09-2003, 02:18 PM
mshay
mshay's Avatar
Default Re: Factory alarm deactivation on an '85 (DF)
Anybody else? Kick panel or behind the breadbox? I actually removed the pad a few months ago. Wish I remembered what was behind it. I'm still in Kuwait so I won't be able to do the work for a few months. Got plenty of time to hear from everybody. Thanks!
:flag
Old 08-09-2003, 02:37 PM
DF
DF's Avatar
It is definately behind the breadbox on my 85.
Old 08-10-2003, 07:39 AM
mshay
mshay's Avatar
Thanks. One more question can I just disconnect it? Does it control anything else besides the damn alarm?
Mike
:flag
Old 08-10-2003, 11:11 AM
nobodyunknown
nobodyunknown's Avatar
Usually the problem with the alarm is the door lock switches.
Old 08-10-2003, 11:52 AM
frank moran
frank moran's Avatar
the silver box you refer too behind the bread box is the burn off module, used only on an 85, you need this.
Old 08-10-2003, 05:03 PM
DF
DF's Avatar
Default Re: Factory alarm deactivation on an '85 (frank moran)
Well, I checked in the shop manual and it is behind the breadbox. It doesn't say if it is black or silver though. I don't know about just disconnecting it as there are other things that have to hook up to it that control other things (ie, the box for controlling the locks is in the console). I am sure someone will chime in that has done this before.
Old 08-10-2003, 09:23 PM
dmorris
dmorris's Avatar
I need the same info. I have to be carefull not to use my electric door locks so the alarm doesn't go off when I unlock the door with the key. I agree that it is probably the door locks that are the problem, but I would just as soon disable the system.
Old 08-11-2003, 09:11 AM
mshay
mshay's Avatar
Default Re: Factory alarm deactivation on an '85 (dmorris)
I'm with you. I just want the thing turned off for good.
Old 08-14-2003, 09:52 AM
mshay
mshay's Avatar
So if it is not the silver box (burn off module), which one is it? Has anybody done this?
[Modified by mshay, 10:21 AM 8/15/2003]
Old 08-18-2003, 08:41 AM
mshay
mshay's Avatar
Anyone?
To Factory alarm deactivation on an '85
Quick Reply: Factory alarm deactivation on an '85
