Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Tires and Wheels
- Why are My Tires Wearing Unevenly?
Guide to diagnose trouble with recommended solutions
Will a bad wheel bearing cause uneven tire wear?
I'm buying new tires and I just noticed that my passenger side rear tire wore out the inside of the tread while the outside tread still looks ok. All the other tires seemed to wear evenly. I am also still diagnosing whether or not I have a bad wheel bearing and was wondering if this could be the cause or if it is just an alignment issue. :cheers:
Re: Will a bad wheel bearing cause uneven tire wear? (MtlSphere)
But it could be aligment issue too. So, lift the corner up and check if there is excessive play in the bearing - don't just go and buy new bearings. You could just be wasting your money.
Toni
Toni
Re: Will a bad wheel bearing cause uneven tire wear? (1995LT1)
When you install the new tires have it aligned. Bearing would have to be so bad that it would cause severe vibration to wear the tire. Maybe time to replace the bushings.
Sounds like a 4 wheel alignment is in order.
The bearing would have to be close to falling apart to get that much uneveness :smash:
Re: Will a bad wheel bearing cause uneven tire wear? (AGENT 86)
