C5 Rims on a C4, do they stick out like ZR1 rims?
Does anyone know if a 10.5" rim backspaced for a C5 would stick out as far as a GS offset rim or a ZR1 rim?
Jim :steering:
Jim :steering:
Re: C5 Rims on a C4, do they stick out like ZR1 rims? (Hammer)
My feeling is that they wont because I belive the offset is in the sixty something mm range. It would be nice to know for sure so if anyone out there is running 18x10.5 let us know how they fit.
Location: Almost all Skyline Cruises Vettes at Waterside 1-5
1 Post
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Are you speaking of a stock C5 rim on an 88 and up (not ZR 1 or GS)?
If you are, the wheels do not "stick out" They fit just like original
:seeya
:seeya
hammer,
Kevin has my C5 wheels. Give him a shout.
....I need to stop giving him free stuff:lol:
thats 4 drag tires, 4 C5 wheels and 2 MT sportman I patterns now...and 2 deli sandwhiches:lol:
I am not too sure about the 10.5" but I have the 9.5" Y2K's and they are the opposite. Sort of "tucked in". They still look nice.
Hammer, we'll have to meet up at one of the corvette challenges at Englishtown next year. I'd like to see your car. :yesnod: :cheers:
Re: C5 Rims on a C4, do they stick out like ZR1 rims? (Jay 383)
HeyJim.....
I think the 10.5" would fit it perfectly.... I havent gotten the C5 rims on my car yet.. but everyone else says they tuck under a tiny bit... So the etra inch prolly puts it right where it should be :thumbs:
Coming down the the finish line wiht that thing... Cant wait :steering:
Good luck,
Ron
Thanks for all the help guys!
Jay, I went to one challenge last year, I'm going to more next year. I may even try and compete.
Kevin, It's coming close, You know it's too long when your dreaming about it. :crazy:
Lspalding, Tell me about your 383 setup!!
RonRed89, tell me about your 396!!
The OE C5 wheels are 18x9.5" on the rear. OE Z06's are 18x10.5" on the rear (offset= 58mm). I've got rear Z06's on the front and back.
They fit fine with 295's on the front.
But they rub a *little* on the back (also with 295's). I've just never got around to bending or removing the splash shield. The tire doesn't hit anything else, just the splash shield.
There is plenty of clearance on the outside of the wheelwell so I might get a slim (~1/8") spacer. But the rub isn't bad enough.
Re: C5 Rims on a C4, do they stick out like ZR1 rims? (chaos on wheels)
chaos,
Thanks for the info.
I originally wanted to go with 10" fronts and was thinking about going smaller.
After seeing your post, I'm holding out for what I want.
Jim
Jim
How is yours coming? I know that it's been a long time in the making for you too. I haven't had my car running reliably now for 2 seasons. This build will change all of that I'm sure.
Back to the wheels, you might want to consider going custom (CCW, Simmons, HRE, Fikse for example). You eliminate a lot of the potential issues of rubbing and fitment as you can get exactly what you want made. My Simmons were custom made as are all of the Fikse/CCW/HRE etc.. and I haven't had a lick of trouble with them.
Good luck,
Ron
Here's a pic of 'zelements' car with 18's all around.
Ron
Re: C5 Rims on a C4, do they stick out like ZR1 rims? (RonRed89)
It's been down for over a year, finally coming to an end now... I was planning on using a custom wheel when the time came, but a set of Fikse FM5's from a C5 are available. I'm going to pass and wait until I have the money to purchase exactly what I want.
Jim
Jim
