Which coolant sensor is the analog gauge? (92 LT1)
Is the sensor in the head, or the senor in water pump the temp. sensor for the analog gauge?
Cruise-In II Veteran
Re: Which coolant sensor is the analog gauge? (neat)
Of those two sensors I think the one under the intake is still going to the ECM.
Do you have one in the block between #6 & #8 plugs? This one used to go to the digital gauges. Since you have an analog readout it looks like the sensor in the water pump is it.
Re: Which coolant sensor is the analog gauge? (65Z01)
I'll say it again, the temp sensor in the head controls the analog temp gauge.
[Modified by STL94LT1, 2:54 PM 3/29/2004]
Re: Which coolant sensor is the analog gauge? (STL94LT1)
I think he meant the two-wire one in the water pump, and the water pump is under the intake, so...
:D
:D
There is no coolant temp sensor under or on the intake of a LT1. The LT1 has a dry intake, no coolant flow.
1 Post
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
Re: Which coolant sensor is the analog gauge? (Lone Ranger)
On my 89 the coollant temp sensor for gage is on passenger side of block. I thought it was the know sensor but I unplugged it one-day to see how car ran without knock sensor and the gauge dropped to low. Drove for about 50 miles and still no temp reading . So when i stopped for gas I plugged it back in burned the shot out of my hands and what do you know my water temp was 180deg.
