1.5 or 1.6" roller rockers. L-98 LPE. 219 cam
I have some D-113 heads, 3/8 screw in studs, guide plates, edelbrock valve springs, LPE. 119 duration cam w/.560" lift with 1.6 rockers. Should I go with the 1.6 or 1.5 rockers. Would the 1.6 clear the valve covers? There not stock one's but look to be stock hight. Just wondering if anyone had a problem with the 1.6 rockes not clearing a stock valve cover hight. :cheers:
Re: 1.5 or 1.6" roller rockers. L-98 LPE. 219 cam (redfast)
You'll always want as much lift as you can get, with a given duration. Choose your duration first, then maximize lift. Lift = torque. So its 1.6RR's.
Stock valve covers will be fine; you'll need to simply grind down the oil drip tabs by 2/3 or greater using a dremel, and grind in the sides of the bolt towers as well. You should be all set after that.
Re: 1.5 or 1.6" roller rockers. L-98 LPE. 219 cam (bradvette)
Did exactly that and works fine.
Cruise-In II Veteran
If those springs are singles with damper, check to see if they are recommended for anything over .520" lift.
Also check for coil bind point with that much lift; it must be enough below (your minimum installed height with 1.6:1 RRs) 1.14" if install height is 1.7".
Re: 1.5 or 1.6" roller rockers. L-98 LPE. 219 cam (65Z01)
I am running 113 heads and the 219 and 1.6 rockers on both sides. With that said I may go to 1.5 rockers on the intake side this season to bring my powerband a little lower and increase throttle response.
Re: 1.5 or 1.6" roller rockers. L-98 LPE. 219 cam (scorp508)
Re: 1.5 or 1.6" roller rockers. L-98 LPE. 219 cam (Wheelman)
Scorp does this apply to engines closer to stock as well, or would i be better off with 1.6 all around?
When I contacted LPE, TPIS, and AFR about my setup, they all recommended 1.6 on both sides. But I think that by experimenting, one might find the right combo to eke out the most power possible.......
No 2 engines are identical and I feel that for my own personal engine the 1.5s may be better suited for my cylinder heads which may not have as nice of a port job as an LPE 113 may. Lift is nice if you can use it.
Great replies :thumbs: What would my low end torque look like with this setup. I have a 4+3. Another reason I was considering the 1.5 rr to keep the power allitle more on the low end. But I don't think it would make a difference :cheers:
red, I see you are also from Massachusetts. I should have a new clutch in my car within the next week or two. Mine is also a superam/219/1.6/full exhaust/4+3 car. When I get it broken in I'd be glad to give you a ride or let you drive it. She needs more tuning, but it is still a fun time.
