Plenum coolant bypass
I decided to take a weekend off from porting intakes and work on my own car. I had it apart anyhow to change out the starter and coil packs so I thought why not get rid of that pesky coolant flowing through the plenum. Here are a couple of pics of my new set up.
To make a long story short I closed off the plenum coolant holes in the injector housings with set screws and installed pipe fittings on the coolant pipes. Then I routed lines from the new coolant pipe fittings to a Y block which dumps the coolant back into the upper reservoir. Volia, no more draining coolant for plenum pulls and air bleed still works like stock.
Location: Thornton,Co. Press 1 to Proceed in English or 2 for Deportation ...don't let the fence hit you in the azz!
Nice......that black crome color looks awesome, I did the same with my coolant holes in the IH's last year and it makes life a lot easier when pullin the plenum!!!
Ry
Ry
Hey Loco can you email me those pics in High resolution. I am curious. Thanks
jalbertini@midsouth.rr.com
I like it!!!! Very nice....you could market a kit for this. By the way, I'm going to try to send my plenum and IH to you and Jeffvette for the package deal. I discussed with Jeff and hopefully next winter and hopefully slow months for you folks.
Craig
Craig
Craig
Craig
Craig
Craig
Post a detailed procedure for us at least.
Very cool looking color on that motor BTW.
Rick
Hey Canadian Mike, don't worry bud, I'll get right back to porting your plenum just as soon as I finish these last coupla beers - oh and after I find my chainsaw.
Glad ya'll like it. I plan to do a full write up on this project for the "Heart of the Beast", keep an eye out for it.
I'll do that!
Craig
Craig
Cruise-In I Veteran
I like the looks of that setup. And looking forward to seeing a full write up.
What are the pros for installing the coolant bypass (aside from the obvious)?
Any downsides? Just curious why it was even a part of the LT5 in the first place.
George
George
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'05-'06-'10-'11-'12
George
George
Isn't that why there is coolant flowing through the TB? I'm talking about the plenum. The LT1 and LT4's have dry plenums but still use the TB coolant pass-through. Why can't the LT5 operate in the same fashion?
Originally Posted by Jeffvette
Ok Doc, coolant does go through the plenum. Comes in the sides by the TB and goes through a channel and then gets routed into the TB.
That is simply a tiny part of the plenum 'just' to get to the throttle body - and bypassing it (the throttle body) also negates the coolant in this part of the plenum. THUS............since there is no other part of the plenum with coolant, it is essentially dry (if you know what I mean, and I know you do!).
