What tires on you running on your 17" wheels???
I'm running the GY GSD3 275's up front and 315's in rear. I've really enjoyed those tires, and have my best 60' on them, even quicker than my BFG Drag Radials. I think they handle and look great; I like the tread pattern on them, too.
I have been using the new discontinued V700 Ecsta with some apparent tread but in a dot racing compound. However simply due to age they need replacing. I will look at the Nittos.
I am also in the 200 mile/year range.
Edit: I see Nitto has the NT-01 DOT 6/32nds competition tire in 275/315 sizes in 17 inch. That should be a US legal replacement for the Kumho V700 Ecsta I now use and the V710 that others use.
Not likely to get a lot of miles but I am expecting that not many of us drive our C4s that much anymore at all.
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
275's up front and 315's in the rear.
Ran them on the track at New Jersey Motorsport's Park and they cornered like she was on rails.
Received 1,870 Likes
Nitto 555's or Invo's are also excellent tires though not sure the latter is available in ZR-1 sizing.
NCM Lifetime # 982
Would these tires fit ?
Toyo Proxies
P345/40R17
LL
Max Load 2094 lbs.
Max Pressure 44 psi
Tread Depth 6/32"
Tire weight 35 lbs.
Rim Width 11.5-13.5"
Measured Rim Width 12"
Section Width 13.7"
Tread Width 13.4"
Overall Diameter 27.7"
Revolutions Per Mile 749
Toyo Proxies
P345/40R17
LL
Max Load 2094 lbs.
Max Pressure 44 psi
Tread Depth 6/32"
Tire weight 35 lbs.
Section Width 13.7"
Tread Width 13.4"
#35
My tires have plenty of tread (started at 6/32nds and still are at 4/32nds but they must be 12 years old by now. I better get out and put some miles on the car.
#36
I dont have a ZR-1 but I do have a set of 91' ZR-1 Sawblades on it and run the Mickey Thompson Street Comps. I'm happy with them.
http://www.jegs.com/p/Mickey-Thompson/Mickey-Thompson-Street-Comp-Radial-Tires/2169162/10002/-1[/URL]2/10002/-1
#37
the nittos nt05 look like a good choice
I love the polished a molds look great
I need some nittos but I'm gonna wear out the hoosiers first!
hopefully by spring I'll be on some fresh rubber and it will likely be NT05 or Toyo RA1 like those too I have them on the turbo car and they are a great all around tire
