Water pump change?
Water pump change?
OK folks I managed to destroy a water pump but don't have a clue as to why it failed.
Was in a parade for a car show only averaging about 40 kms when I started getting what sounded to me like a clutch rattle. Then over the next few minutes the temperature started to climb.Not being particularly brave in high 30'sC temps I pulled to the side of the road. Saw the coolant pouring out behind the pulley. Put the car on a recovery vehicle to my shop. Have managed to locate and purchase a new water pump and it is on its way over here to Dubai.
Any experienced words of wisdom, advice or tips and tricks on the replacement procedure? Have only taken the plenum off a few times but don't consider myself an "experienced" LT-5 wrench. All comments and advice is greatly appreciated.
Capt.
Capt.
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Not a bad job at all.
Take pics, get a piece of cardboard and make a drawing of the pump and where the bolts go they are not all the same.
http://zr1.net/forum/showthread.php?t=14475
Go to post 108 scowl down to water pump.
https://www.corvetteforum.com/forums...post1583616157
captcorvette (04-24-2016)
captcorvette (04-25-2016)
Coolant Hose Clamp Tool
Can you get the Clamp Tool (it turns out there are many styles) into position on the LT5 on all hose clamps?
I used a combination of channel locks and screw drivers and finally had to use a mini Air Grinder. Then I cut the wrong place because the hose clamps still clamps without cutting almost 180 deg on each clamp.
Then on original Coolant Hoses that have never before been removed they are glued on and you have to cut the coolant hose lengthwise on the connection with razor blade and followed by the use of a flat screw driver.
I have a method to remove the Cam Covers Engine In Car that is easier than what I had to do to remove a Water Pump hose on this 95'
On that Water Pump Hose.....installing a New Coolant Hose I locate the New Stainless Steel Hose Clamp (with a 7mm/flat screw driver tightening nut) such that the Hose Clamp Nut is accessible from the bottom using an extension on a 1/4 inch socket wrench and 7mm socket (very easy from under the car). And those special hose clamps used on Silicon Hoses (Hose Clamp has rounded edges for Silicon Hose) are the best having the 7mm nut which is a lot better than using a Flat Screw Driver.
You are absolutely correct.......it took me 3 hours to remove that water pump clamp on a 95' just last week. Do you have a photo of that Clamp Tool you are referring to and are all of those original clamps the same orientation on each hose?
Rich
This is the kind I used, with a cable and you can get it into just about any position you need to. I wouldn't even attempt this job without this little gem....Make the job so much easier. Once you have it on the clamp, you compress it and it locks open and you just slip the clamp back and Whola!
Rich
Amazon.com: OTC 4525 Cable-Type Flexible Hose Clamp Pliers: Automotive
Rich
Received 3,043 Likes
St. Jude Donor '05
Does Samco still make those hose kits they were nice just use the smooth stainless clamps ez duz it. Would be a good time to replace
May be some bolts hidden under grease there are plenty of them
Oh and have some xanax handy.
It sounds like your bearing failed and took out the seal.
I don't know what brand of water pump you ordered as in, NOS, or rebuilt, or aftermarket. What I do know is the aftermarket pump I installed does not seem to flow the volume of coolant necessary
to keep the engine cool at freeway speeds in 6th gear. I bought it off John Sullivan ( I think ) over 10 years ago. My solution ( thanks to Hib ) for that is to use a 180 degree thermostat and drill two 1/8 inch holes in
the flange area that will allow more coolant to pass through it all the time. Granted, my Z is a bit different with 3.07 gears and a Ron Davis all aluminum radiator installed.
My observation was the new pump simply did not move the coolant through the system at the same flow rate as the original equipment pump that was replaced.
I am not suggesting you drill the thermostat for your car. I am simply letting you know this is what I had to do to get the coolant out of the motor quickly enough to keep it in the normal operating range when
cruising in the 70+ mph range in 6th gear.
captcorvette (04-26-2016)
St. Jude Donor '16
Edit: I have 3.73"s in my 91 and like it for 70-75 in 6th.
St. Jude Donor '05
curious too
with 4.09 gears 6th the engine wasnt real happy
ZRx do a lot of hwy driving or higher speed stuff?
Purchased an OEM from a friend's Cheby agency in the USA. It is constantly 40+C here in the summer time. I have installed big mouth type air intake under the car on all my C4's. Temps run a bit higher than I would like but well within operating parameters. Use a water wetter additive and keep a constant vigil on temps. Yes the bearing went south on me. The surprise was it happened quickly. Noise only started a few minutes (at idle) then the coolant evacuated one me. Got a bit lucky this time eh? Thanks again for all the input and valuable advice.
Capt.
Capt.
I have about 140K on my Z with approximately the last 70k using 3.07s. After a while I got use to them and now have grown to like them.
I recently ran some 4.10 like which is the same gear it had when I bought it back in 03. I found them to be to deep for the street. I even tried some 4.33s once... wow... 3 grand at a 100 mph. To short.
Why do I run 3.07s? Other than occasional extra clutch slippage to get rolling up hill there are several benefits. Improved gas milage under
good conditions, less shifting, and if I ever take it to the strip I will only shift twice. The top of third gear is about 127+ mph with 24.5 tall tires.
I can't say it has slowed the car down all that much acceleration wise. Under the right conditions ( less than ideal ) pushing the pedal will cause a little tire spin around 4500 rpm on the way to 7000 rpm.
Its also the right gear for ORRs wherever they happen to happen !
You can have some gear calculating fun here and see it all.
http://www.angelfire.com/fl/procrastination/rear.html
FASTAZU (04-26-2016)
