DIY Dual fuel pump system?
I'm considering setting up dual fuel pumps.
I bought a new Walbro 255lph pump, I would like to set that up as the main pump. The old Walbro pump I'll hook to the boost-a-pump, and run two fuel hoses to the rails (with filters and checkvalves). The old metal line I'll use as a return line. I'll either use a '98 fuel rail and regulator or I'd need to buy aftermarket rails.
Has this been done before? Any lessons learned with this plan?
1 Post
I bought a new Walbro 225lph pump, I would like to set that up as the main pump. The old Walbro pump I'll hook to the boost-a-pump, and run two fuel hoses to the rails (with filters and checkvalves). The old metal line I'll use as a return line. I'll either use a '98 fuel rail and regulator or I'd need to buy aftermarket rails.
Not sure if it's released though.
Mike
Location: Tinker till it blows... then back it off a notch, maybe!!
St. Jude Donor '08
Plus there are some here that will help and answer your questions
http://forums.corvetteforum.com/show....php?t=1769487
Understand FIRST then proceed.
There are many others that have done this stuff as well, so I guess that the lesson learned is that if you understand how it needs to be , then you save money. If not, then you pay the piper.
btw: you can probably get away with one regulator...boost referenced works well
Good luck with it.
rjw
Thanks! Since I'm playing with flammables I am thinking twice. I have a bit of time since I just recruited Robert at Advanced Dyno to build a new LS2 forged shortblock for me (with Diamond custom boost pistons). It's nice to use an S.F. bay area shop that both builds engines and can do the dyno. It also means the fuel upgrade results will have supervision.
After looking at the tanks I'll put the new pump in the passenger side tank and leave the drivers tank as is but for the return line line and new fuel line. I can simplify the dual hoses to one 1/2" (-10AN) line and a distribution block. Pretty much all that's left is to get a fuel regulator (price goes up though with -10AN input).
Not sure why others are putting both pumps in one tank, it would seem to generate more heat. Is it just fewer tanks modified?
I think a single bigger line is cleaner than dual hoses, any reason to run two hoses?
I noticed there were no check valves in the thread you referenced. I believe at least one would be needed for the part-time pump.
No, I have more time than money. Fuel pump - $80, hoses $100, checkvalve $40, and fuel pressure regulator $120. A little thinking and $340 is better than $1,500-$1,800. Figuring it out and working on it is a hobby, why pay someone to do my hobby for me?
St. Jude Donor '08
Arnel
Received 1,817 Likes
I've been using the dual pumpers for years on the turbo buicks and I only have one concern, when the secondary pump fails, the car leans out and goes boom.
is there a single intank (quiet) that will support over 800 rwhp???
I think aeromotive might have something. if that one pump goes, the car stops, but keeping one BIG pump cool and having it running all the time can be an issue. I would update to a "return style" fuel system on my 2003 with a better regulator and run one big pump all the time, but it has to be intank for me.
I currently have a racetronix 255 with a BAP and alchy, and I think I'm a bit marginal for the big HP, but it seems to be working at below the 800 rwhp level (which is plenty for me)
Here's a big pump:
http://www.magnumforce.com/magnaflow...ection%20Pumps
Engine Horsepower Range: up to 2,000+*
Rail Pressure: 20 to 120 psi
12.5V Amp Draw: 10A @ 20 psi, 22.5A @100 psi
MAGMP-4701
Pro Star 600 EFI pump
Price: $850.00
St. Jude Donor '08
What if the one big pump fails?
Here's a big pump:
MAGMP-4701
Price: $850.00
Here's a big pump:
MAGMP-4701
Price: $850.00
Here's a big pump:
MAGMP-4701
Price: $850.00
Here's a big pump:
MAGMP-4701
Price: $850.00
that is one big pump!!! bet it sounds like a chain saw
Dan
