How much h.p. with #60 injectors and bap?
Former Vendor
But this is with Methenol,right? Could be very misleading.
I run 60lb injectors with stock pump and BAP to about 600-650rwhp. Mind you this is tuning the fuel pressure drop.With no drop you could probly hit 750-800rwhp.
I've got the A&A S Trim kit with the 60lb injectors and new fuel pump (I think it's an LPE) that comes with his kit and got 563rwhp on Andy's dyno and 561rwhp on Charlie's dyno (with a slipping clutch). I had Charlie re-dyno/tune it because a couple of times running on hot days I got what sounded like knocking when pushing it over 6000rpms.
Charlie saw the fuel pressure dropping to 40lbs on the dyno so he is installing a Boost-A-Pump right now. So I can say this, even with A&A's kit that includes a new fuel pump if you're anywhere near 560rwhp you will probably need a BAP.
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Slowhawk did my tune, i have the 60# and the bap and i dynoed 643rwhp
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
I am running 800 rwhp with 60# injectors, BAP, and Racetronix. Fuel pressure would drop at the very top. I am in the middle of installing a Stage 2 ECS fuel system and will continue to use the 60's for now but may have to upgrade due to a couple of other changes I am making.
I think it makes a difference if you have a return style system as well. A returnless system will show a pressure drop sooner than a return style. That is what we have seen
i have 60# injectors, and a kenne belle boostapump, and im making 650ish at the wheels. I need an upgrade return line system, whos is the best? Im putting in a single pump, im sick of this boostapump multipump nonsense... i just want one big pump. Any advice?
