TTi and Gear ratio
Old 11-27-2008, 10:44 AM
TheBigDog
TheBigDog's Avatar
Default TTi and Gear ratio
Since installing my TTi kit I was wondering what would happen if I go from a 2:73 ratio to a 3:42 ratio. I know there would be an increase in HP and torque, but not sure how to calculate. Lets assume that my HP is 550 and 490 ft lbs of torque...can some of you math wizards calculate the benifits increases in changing rear ends
Thanks,
The Big Dog
Old 11-27-2008, 11:09 AM
Chris Stewart
Chris Stewart's Avatar
I don't think a gear change will make any more power on the dyno, it might even lose some. It will help pull thru the powerband and finish the race at higher RPM. It will make better ET, at the expense of roughly 500rpm higher at cruising speed.
Old 11-27-2008, 11:36 AM
SpeedyD
SpeedyD's Avatar
It will actually lose power on the dyno. It will have more pick up but a lower top speed.
Dan
To TTi and Gear ratio
Quick Reply: TTi and Gear ratio
