Street Legal Cam for Superchargers???
Old 12-30-2008, 11:12 PM
Z06FRC
Z06FRC's Avatar
Default Street Legal Cam for Superchargers???
I own a 99 vette that'll be supercharged with a Vortech system. I want to know if one or both of these cams are capable of passing smog/emissions test? They are both listed below. I would also like some input on these cams or any other cams I haven't mentions.
Crane Cams
Part Number: CRN-1449561
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 2,000-6,200
Intake Duration at 050 inch Lift: 216
Exhaust Duration at 050 inch Lift: 224
Duration at 050 inch Lift: 216 int./224 exh.
Advertised Intake Duration: 278
Advertised Exhaust Duration: 286
Advertised Duration: 278 int./286 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.551 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.551 in.
Valve Lift with Factory Rocker Arm Ratio: 0.551 int./0.551 exh. lift
Lobe Separation (degrees): 115
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Comp Cams
Part Number: CCA-54-424-11
Basic Operating RPM Range: 1,500-6,800
Intake Duration at 050 inch Lift: 212
Exhaust Duration at 050 inch Lift: 218
Duration at 050 inch Lift: 212 int./218 exh.
Advertised Intake Duration: 265
Advertised Exhaust Duration: 271
Advertised Duration: 265 int./271 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.558 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.563 in.
Valve Lift with Factory Rocker Arm Ratio: 0.558 int./0.563 exh. lift
Old 12-31-2008, 09:08 AM
chaase
chaase's Avatar
St. Jude Donor '12
Does Toronto use the ODBII port to check the engine readiness? Either way, that is a mild cam and should pass the sniffer test with a good tune.
Old 12-31-2008, 09:53 AM
0Arun@ChampionMotors
Former Vendor
Arun@ChampionMotors's Avatar
Best bet and cost effectiveness would be a 02 and up Z06 cam. No brainer for an e-test and will make 500-590 rwhp with ease.
Old 12-31-2008, 12:40 PM
Z06FRC
Z06FRC's Avatar
How will the Z06 cam do compare to the Comp Cam?
02+ Z06 Cam
Part Number: NAL-12565308
Basic Operating RPM Range: 1,500-5,200
Intake Duration at 050 inch Lift: 204
Duration at 050 inch Lift: 204 int./218 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.550 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.550 in.
Valve Lift with Factory Rocker Arm Ratio: 0.550 int./0.550 exh. lift
Lobe Separation (degrees): 117
Old 12-31-2008, 03:16 PM
Former Vendor
02+ Z06 Cam
Maybe a 10 rwhp difference-when price is considered and the fact you want to pass a drive clean it's a clear winner.
Old 12-31-2008, 04:17 PM
chriswtx
chriswtx's Avatar
ECS has made 740rwhp with the stock Z06 cam...
Old 12-31-2008, 04:18 PM
Z06FRC
Z06FRC's Avatar
Then Z06 cam it is. I have a member of this forum offering me $150 cdn for one with 10k on it.
Old 01-01-2009, 11:50 AM
Former Vendor
Perfect-just make sure it's 02 and later.
Old 01-02-2009, 01:36 PM
vetterlatethannever
vetterlatethannever's Avatar
Old 01-02-2009, 11:01 PM
C5Spirit
C5Spirit's Avatar
'04 ZO6 cam
It works great for me...
'97 C5 A4
Patriot heads with dual springs and milled to 62cc.
LG headers
LS6 ported intake and TB
Methanol system..
Vortech V2 SQ S-trim putting out 10 lbs of boost
556RWHP and 511RWTQ
The car runs and idle like stock
Last time at the track it ran 11.3@126MPH.
To Street Legal Cam for Superchargers???
Quick Reply: Street Legal Cam for Superchargers???
