My methanol in windshield fluid reservoir is leaking what's common cause?
Old 03-25-2009, 03:43 PM
Suks2bu
Suks2bu's Avatar
If you have one of the old kits like mine, It was leaking threw the windshield pump motor seal so i pulled the motor out and capped the hole. I think Julio says to do that on the new kits ? Meth will hurt your garage tile floor ask me how i know
Old 03-25-2009, 05:16 PM
clemsondave
clemsondave's Avatar
Fill the tank up, reach your hand down to where the fitting on the bottom is. If there is a leak, you will feel it. I've tried the RTV silicone before, it doesn't last very long. The meth eats right through it. As mentioned above, I called Julio and ordered new fittings and washers.
If there is no leak there, check around the pump. The internal grommets or seal could be failing.
Old 03-28-2009, 02:45 PM
FactoryRaceCar
Support Corvetteforum!
FactoryRaceCar's Avatar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Jim what do you run for alky in the tank? Is it 100% pure meth M1 or something else?
Old 03-28-2009, 06:37 PM
C5Spirit
C5Spirit's Avatar
I just did a permanent fix on mine with JB Wield....
Old 03-29-2009, 12:57 AM
Mopar Jimmy
Mopar Jimmy's Avatar
Location: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
100% pure meth from Torco Racing Fuels!
Old 04-15-2013, 10:35 PM
os4car
os4car's Avatar
Where was the leak coming from?
I think I have the same problem
Old 04-15-2013, 10:56 PM
Blue Time
Blue Time's Avatar
I have his car now. I believe he told me he had to replace the pump when
I bought it. I'm sure he will reply if he sees this post.
Old 04-15-2013, 11:12 PM
joshtownsend
joshtownsend's Avatar
guys, there is only 3 holes on the tank..
1. where the old motor is that use wont use anymore, just pull it and put something in there,bolt,cap,rubber gasket, then rtv around it.
2. the sensor that reads the level of the fluid in the tank, seal around that as well with rtv
3. the hole you cut to allow meth to flow to the pump. It should be tight but rtv around that as well.
Allow all the dry and you can run 100% meth for years and year without any issues..
And don't worry.. last time i judged a car show, i didn't see where deductions were taken off for to much RTV being uses!!
Old 04-16-2013, 01:06 AM
PhysicsDude55
PhysicsDude55's Avatar
If you read the fine print, most meth injection systems aren't rated for 100% meth, and will tell you to only use 50/50 at the strongest.
AlkyControl I believe is the only kit I'm aware of that says their lines and pumps are rated for 100% methanol.
If you don't have an Alkycontrol kit, then its likely your lines or pump have developed a leak somewhere.
Maybe put water in it, and pressurize the washer tank in the same way as doing a compression check on a cooling system and see if you can find any leaks.
Old 04-16-2013, 01:36 AM
Y2KRoadster
Y2KRoadster's Avatar
Did you seriously just revive a thread that was over 4 years old? Start your own thread man.
Old 04-22-2013, 04:32 PM
_zebra
_zebra's Avatar
Julio will be the first to tell you a pump running 100% should be rebuilt every couple years or it will start leaking/failing.
and straight meth flashes around 60-70°, so if it's leaking on the floor, won't it evaporate within a few minutes?
thus making the search function useless. gotta love rules
Old 01-18-2017, 12:57 PM
derekd7987
derekd7987's Avatar
Originally Posted by 4DRUSH
Once I thought I had a windsheild washer tank leak. Turns out the bottom of the innercooler was full of alky. I also had/have the older kit, and ECS added something (check valve?) that fixed the problem.
I realize this thread is very old and already has been revived once but I wanted to comment incase somebody searches this and has the same problem I had.
I couldn't find a leak either, and like above, my intercooler was extremely full of meth. I noticed when I was changing my front sway bar and had to remove the pipe coming from passenger side of intercooler and about a gallon of meth poured out.
The check valve statement is correct. On a C5 the washer fluid tank is higher than the meth nozzle so it will gravity feed straight into the charge pipe and run down into the intercooler. I had a shop install my alky kit and they left the check valve out. I goes between the nozzle itself and the stainless line.
For me this made the car extremely hard to start and took awhile for the car to clean up and idle right.
Again, sorry to revive an old thread but was just hoping this would help somebody like me that couldn't find a leak at the tank or anywhere.
Quick Reply: My methanol in windshield fluid reservoir is leaking what's common cause?
