A&A Corvette Performance:Forced Induction Q&A thread
#861
Very disappointed in the A&A Kit. Wish I would have went a different route.
Has anyone had problems with the c6 A&A Kit? I spent thousands of dollars on the kit thinking I was getting a good quality kit. First off. We got the kit completely installed and notticed the brand new radiator that they supplied with the kit leaked. So they sent a new one. Then Josh told me he probably sent us a bad bracket. Which he claimed he sent out multiple bad brackets. So now we had to take the car apart again to replace that. They didn't have a black one so he just sent me a polished one. So the kit doesn't match. Then their was one missing part. It was the t fitting that went into the brake boosted for the bov. He had to send that also. After the car being tuned for three weeks and 430 miles now the belt snapped in half that they supplied and left me stranded on the side of the road. I am very disappointed with this kit. I wanted to let other people know just in case you are looking at the kit. Been trying to get a hold of Andy all day and he has not responded. Anyone looking to supercharge their car I would go a different route. At this point I do not recommend it. I hope Andy gives me a call back very soon...
#862
Platinum Supporting Vendor
He was just pissed off because I didn't call him right back. We're actually closed on Mondays ( except for Josh taking orders and answering the phones)and I was 20 miles offshore doing a little fishing.
I called him when I got back in and got the message.
He's young and jumped the gun a little. ( I used to be like that 30 or so years ago )
He had it installed by someone that I don't know. I'm having him take it to one of my known installers to look it over.
He has an issue and we'll figure it out. -Andy
#863
Josh, I will be getting an A&A kit on my C5Z soon. The car has long tube headers. Getting a Hawks thirdgen custom ground blower cam installed next month. I was just wondering what is the best trim and set up will be. I want the car to run on pump gas. Bruce @ Hawks will be doing the install. What pulley, etc to go with?
#864
#865
I'd say a V3 Si or V3 Ti will work perfect and a 3.8" will make plenty of power since you will already have cam and headers. If staying pump gas only we usually don't go past 600rwhp. But talk to Bruce to confirm how he wants to set it up since he will be doing the work and tuning. It's gonna be a beast with boost!
#866
#867
How would you compare the sound of the turbo smart race port and the big bubba to the tial q in the competitors kit? Are both louder than the tial q? Or just the big bubba and the race port quieter or similar?
#868
If you want loud, get the Big Bubba with a trumpet and have it exhaust out the wheel well.
#869
#870
The 50mm Raceport looks nearly identical to the Tial, only more compact housing. Both Vent-to-Atmosphere the same way. If you like the sound of a Tial then you will like the RP.
#871
Simple question but I should ask.
When the A&A Si kit was installed at the A&A shop, I had snaps installed to accept a GM bra. When the installation was complete the screws W/ snap for a head were removed. These were located on the lower front where the lower portion of the bra attaches under the front. I assumed this was done for one of two reasons. The techs (Andy's techs) simply installed the hardware that comes in the kit. The second would be that the fairing screws with snap heads were simply not strong enough to be used (would they have been sheared off?)? I would like to be able to attach the bra securely. Can I use the marine screws with snap heads in my fairing with a GM bra? Will they shear off if I do?
#872
[QUOTE=SDLS1Rider;1592333848]Simple question but I should ask.
Thanks[/QUOTE
Will....As long as you get the proper size the marine snaps w/screws will work just fine! I`ve had them on my car for a long time without issues.
Cheers, RTR
Thanks[/QUOTE
Cheers, RTR
#873
Cheers, RTR
Cheers, RTR
__________________
Thanks, Josh Dodson
PLEASE TAKE A MOMENT TO VISIT OUR NEW WEBSITE AT WWW.AACORVETTE.COM
NOW PARTNERING WITH AFFIRM TO OFFER INTEREST FREE FINANCING!
A&A CORVETTE PERFORMANCE
477 LAMBERT ST Ste A
OXNARD CA 93036
(805) 278-4107
Instagram @aacorvettesuperchargers
• Facebook.com/AACorvette •
Thanks, Josh Dodson
OXNARD CA 93036
(805) 278-4107
#874
I have a question about the Vortech V2Si (that uses engine oil for lubrication). I want to know if it's possible or if anyone has done it, to use, say, an LS7 dry sump tank or similar custom oil container and one of those electric oil pumps that the STS rear turbo guys use on a Vortech. Seems to me it would allow the unit to run pretty cool without the hot engine oil circulating through it, my only concern would be would the oil get warm/hot enough to flow well ? Could you run thinner oil, even non-motor oil ? Thanks .
#875
Can the V2 Si be upgraded to : T trim, Ti trim, or (using aftermarket parts, namely a new volute) to a YSi trim level ? I want BIG power, I have the iron block, all forged setup, might as well push it. Deep 9s would be awesome...or can I plumb my FAST 90 for a N20 fogger and a plate for 2 stages of nitrous (rather not)...Thanks !
#876
Superchargerrebuild.com says they can upgrade any blower ( they have the aftermarket volute to go even to YSi ) they say... I can't imagine you can't go T or Ti trim from Si either.
#878
Build details have changed from email with acquisition of an LS3 long block and 90mm Holley Hi Ram intake, so cam is 224/236 @ .050 116 LSA NEGATIVE 2 degrees overlap, .600ish lift intake/exhaust, ported LS3 heads, same ported LS2 T-body, upgrading to 2" headers from 1 7/8" to 2 " step, trans will be TH400 or 'Glide.
Want to convert V2Si to biggest trim possible.
Please advise...
Please advise...
#879
Just heard from superchargerrebuild.com in TX, $1265.00 including shipping and full rebuild plus converting to YSi trim with billet impeller...
#880
You are assuming a lot of risk and the potential to lose money going that route. Looks like they have a strict policy of no refunds and no warranty on that website, just be cautious. Unfortunately I've never heard a good story after people have a SC rebuilt by anyone other than Vortech directly.
