Motor options blown ls1....
Old 08-07-2013, 02:49 PM
evo2ls1
evo2ls1's Avatar
Default Motor options blown ls1....
Hello all, 99frc ls1 with A&A kit car blew on 9lbs piston number 7 and block is no good. What are options seems to be best block for money ect.
Just looking for any first hand info thanks,
Oh and sticking with current blower A&A v3 kit
Old 08-07-2013, 03:47 PM
joshtownsend
joshtownsend's Avatar
You need to figure out what happened first. On 9 lbs, the car should have lasted forever, even on stock internals. It sounds like to much detonation to me because to block the block. After that, if you want to go back with a stock motor, just get a pull out. Or get a used 5.3 block, have it machined and use your stock parts and replace the one piston.
Thats the cheapest.. then it goes up from there.
Old 08-07-2013, 03:52 PM
evo2ls1
evo2ls1's Avatar
Yea I have not quite figured that out but I know anything can happen I plan on going with forged bottom just curious as to what block to use ls1 or is it worth the extra grand to get ls2
Old 08-07-2013, 04:59 PM
Chicago1
Chicago1's Avatar
Doesnt a vendor around here have a forged stocked cubed bottom end for about 4k shipped?
Old 08-07-2013, 05:31 PM
corvette8189
corvette8189's Avatar
I have a used ls6 block, crank, and forged rods and pistons
Lmk ill make u a deal
Old 08-07-2013, 06:30 PM
MVP'S ZO6
ISIS SUCKS FAT CHOAD
Support Corvetteforum!
MVP'S ZO6's Avatar
To the OP if I were you I'd go with an iron block and some good heads.
Old 08-07-2013, 09:18 PM
Robert 2000
Robert 2000's Avatar
And that is what I am doing
Old 08-07-2013, 09:27 PM
MrH00nel2
MrH00nel2's Avatar
Go with an lq9
Old 08-07-2013, 09:40 PM
MVP'S ZO6
MVP'S ZO6's Avatar
Plus 1 on the LQ9. Cheap block as for price and super strong!! It will add about 80 lbs to the front of your car but you can get half of that back by putting your battery in the trunk. However, you have a century setup hanging off there so I'm sure perfect weight distribution isn't at the top of your list.
Old 08-07-2013, 10:52 PM
Robert 2000
Yep I agree with the above posts got my 6.0 L iron block for $700 to my door the only thing I have ever bought off of Ebay.
Old 08-07-2013, 10:59 PM
Blitzkrieg
AKA "The CLOWN"
Blitzkrieg's Avatar
I recommend this! I will build one of these soon.
http://www.aesracing.net/product_info_390LS1.htm
Old 08-07-2013, 11:06 PM
Robert 2000
Get it done and then go run all the 9s you want
Old 08-07-2013, 11:07 PM
MVP'S ZO6
MVP'S ZO6's Avatar
Blitzy, sell the novi 2K and buy a 2200R.
Old 08-07-2013, 11:12 PM
Blitzkrieg
AKA "The CLOWN"
Blitzkrieg's Avatar
I have not spent a $1 on my car this year except for gas and oil change!
I'm enjoying just driving it instead of F***ing with it all the time!
Also I am in the process of building a new house and the wife will slit my throat if I spend money on the TOY!
Old 08-07-2013, 11:18 PM
Blitzkrieg
AKA "The CLOWN"
Blitzkrieg's Avatar
No reason to get rid of the 2000 as I'm not even making it work hard!
House is priority!
Old 08-08-2013, 11:52 PM
evo2ls1
evo2ls1's Avatar
I liked the cost of iron block but i do not want anymore weight on nose of car added too much already lol, options are find Ls6 block or go ahead with ls2 which is probably what I will do after more research, few more cubes ect. Should be a cool setup
Old 08-09-2013, 12:12 AM
_zebra
_zebra's Avatar
didn't you just sell off a bunch of parts you bought for that same engine last year that you gave up on?
To Motor options blown ls1....
Old 08-09-2013, 03:16 AM
Y2KRoadster
Y2KRoadster's Avatar
What are your long term power goals? The LS2 block is great but like other people said, it's a lot cheaper to go with an LQ9...the 80 LBS's isn't that much. Just relocate your battery...no big deal.
Old 08-10-2013, 08:28 AM
Da_Whistler
Da_Whistler's Avatar
Get a stock LS1 block, forged internals and either ported 317 heads or ported 243's. I had Mike at MCP Competition build my setup. Cost effective and makes a boat load of power.
A LS2 swap is nice but frankly for the money the stock cube LS will make lots of power if you want.
Old 08-10-2013, 08:48 AM
RunninRed
RunninRed's Avatar
I'm friends with OP and can definitely say he does NOT want to add anymore weight to the car. Especially the front. This is the guy that debated not doing an A&A because it would add weight. So iron block is out of the question and I agree with that. Not at liberty to say which direction he's chosen, but it's gonna be a beast!
Quick Reply: Motor options blown ls1....
