Question on tensioning belt on A&A kit...
I'm pretty sure it's the older kit. I bought the car already set up and the install was done in '09, not sure if that helps at all. I'm about to tackle a belt change on my car and I'm not sure how the belt is tensioned. Is it manually tensioned like it looks like in the YouTube video A&A did?
Thanks for any help, Jim
Passenger side of car-Release manual tensioner, walk to driver side of car-pull belt as hard as humanly possible off alternator, walk to passenger side of car-unbolt the three mounts, pull the blower back a couple inches, do the damn thing, then flip it and reverse it. Lol
Platinum Supporting Vendor
For reference purposes.
Here is a cool tech tip. Using a 1/2" extension or piece of round aluminum can help lock the automatic tensioner in place and allow you more slack in the belt to get it installed or removed easier.
This trick can be used on the bench before installing s/c or in the car before removing tension off the belt.
