Need some meth input. Come in Meth addicts :)
I'll be running 50/50, Devils Own brew, to be exact(already ordered 4 gallons). My meth pump(alky control super pump) came with a dual nozzle setup using m15s. My goal is to run 8 psi in daily driver mode with zero or very little meth. And then add meth for my "track" setting of 12ish psi. My single turbo setup(TC76, .96ar 68mm turbine) should spool very quickly and I am a lead foot. This is a daily driver and I don't want to have to fill the meth tank more than every couple months. I wont be running a progressive controller. Just an adjustable hobbs switch that I can set between 2-10 psi(devils own). I'd like to just set it at 9-10psi so I only use meth when I want the extra power(or overboost). But I may run it from 7psi for daily safety if it wont use a ton. The car will be SD tuned by my tuner to use the meth, so this isn't an added safety thing I want to fiddle with after the tune. I want to set it up and forget it.
Ok, on to my questions/concerns.
1. How quickly would two m15 nozzles go through my washer tank of meth say if I'm "at the track" beating on it all day?
2. Can I just run a single m15 nozzle(set from 7psi)? If I have it far enough from the TB are there concerns with even distribution/atomization using a single nozzle?
I'd love to hear your input on your meth setup and usage
ISIS SUCKS FAT CHOAD
Beating on it all day a tank maybe.
As for everything else, your just going to have to see what the car likes.
A lot of us that use methanol injection run 100 percent meth. It's used as additional fuel and for the cooling property's it has.
If I had to guess given your boost levels, I'd say you probably don't need all that meth but if tuned right the dual nozzle system will work well for you.
Switching from the devils own single nozzle setup to the alky control dual nozzle setup, your probably going to need to retune.
Edit my bad I see you said single nozzle.
Thanks for the input The reason I chose the 50\50 is first the safety/fire hazard. And also the boiling point of pure meth. Here in hot sunny Florida i dont want it to boil off and evaporate faster than I use it
Im really leaning towards just running the single m15. I suspect it will be enough for my boost level while slowing down the rate I go through it. Then on the dyno we can play with it and decide when to have it come on
I run Alky control 100% with daul 15s here in Texas no evaporate issues but it does eat a tank a week when im daily driving to work 40 miles round trip. @ the track eats a washer tank in about 8-10 passes but mine comes in around 3k rpm!
Doh, thats exactly the kind of consumption i want to avoid. I dont mind if it sucks it down on kill mode, but dont want to burn through it on daily duty. Thanks for the input
You must have your foot in it a lot on those trips to work.
Thats how you ensure that you are in a good mood when you get to work =P And nothing better after a long day there.
Another random question, where did you guys tap the washer tank? I cant find a good flat spot thats low and accessible.
my tank is tapped next to the low level sensor on firewall side.
Received 1,261 Likes
What's the problem with filling it back up? Just throw a 1 gal jug in the rear compartment. Make sure you rinse it out good after drilling the hole on the WW tank.
-Edit- Yep, just looked. They are all strokers with Ysi's lol
This is exactly what I'm thinking. I think I'm just going to go single m15 nozzle and set it to come on at 10psi. Then I wont use any daily driving and a full tank will definitely last me the day at the track.
I'm not looking to use more meth than I need. I would bet the guys that have commented so far are running several hundred more HP than I intend to even in "kill mode" so I have no reason to use as much meth My car isn't a dragster, its a daily driver. I want to be able to hop in it to drive to/from work, the way I like to drive, without my low washer fluid light going off all the time. That's why I'm asking these questions now
Most of the cars around here I can take without even getting into boost
I guess my point is...is the cost of the meth too much for you or something? I would think as cheap as it is, something like this wouldn't be a factor.
I'd set the Hobbs switch for 5 PSI and just run it like that. With your setup...one washer tank will last you a while. During normal driving, you shouldn't hit more than 5 PSI!
