LS2 Throttle body codes on 2001 Z06 with new motor
Hey lads
I was just turning over my new motor and have a bunch of codes relating the new 90mm LS2 throttle body. I have the wire adapter to covert it and have look at the connections, re-seated, etc and all looks fine. Any thoughts?
thx
See codes below:
DTC P1516
Throttle Actuator Control (TAC) Module Throttle Actuator Position Performance
DTC P1518
Throttle Actuator Control (TAC) Module Serial Data Circuit
DTC P1120
Throttle Position (TP) Sensor 1 Circuit
DTC P1220
Throttle Position (TP) Sensor 2 Circuit
DTC P1221
Throttle Position (TP) Sensor 1- 2 Correlation
thx
See codes below:
DTC P1516
DTC P1518
DTC P1120
DTC P1220
DTC P1221
Apparently this could be because of the Adapter harness I am using being wire wrong...any one have the schematics on the se Casper conversion cables ?
thx
thx
^ I had a issue with a harness a little while back. Im impatient lol and summit has them to me next day so instead of troubleshooting the harness lie you, i called summit while i was in the engine bay and ordered another one lol. After the car was up and going, and i wasnt going to get frustrated, i looked the harness over and on of the wires was just so slightly pulled free from the connector, but still in the pigtails, very weird.
