Boost and Internals
Boost and Internals
Been lots of talk about HP and stock internals. My question is how much boost can the stock internals take with out breaking down? An example would be how much boost can the valves take before they leak? At what point does the stock fuel pump run out of gas? I currently at 9.5 lbs. of boost and 500hp. Looking to retune to 600 hp.
Received 1,194 Likes
St. Jude Donor '15
St. Jude Donor '15
Received 1,762 Likes
I know he was thinking about retune to get 600 rwhp.
To the OP here On a stock fuel system with at least a kenne bell BOP hotwire I think you are pushing it and you don't want to run out of fuel on a WOT pull in boost.
On the bottom end it all is just a matter of time when pushing over 2 times the amount of HP.
Heads how many miles on them, a new set of valve spring good valve job...
You should be fine with 600hp just get a boost a pump with a hot wire kit. And some good valve springs
The tune is most important part to keep a stock motor together.
FWIW - When i do the 1/2 mile events i add a gallon or 2 of 100 octane into my tank of 91 (Cali gas).
St. Jude Donor '15
350 hp drive as hard as you want = 100,000 mi plus. Miles@ 600 hp to wheels = money divided by right foot pressure. This has been my experience anyway! This is a very scientific formula haha
My 04' LS6 has been boosted since 07' and never a burp. It's a Novi 2000 tuned and installed by ECS which really that is key, THE TUNE. It see's 7 psi and puts 581whp and 515wtq. I run Meth and a Stock fuel system with a BAP. AR longtubes, hi-flows thru straights. These are safe numbers and really for a 3,100 pound street car it is more then enough. It totally drives like it did when it was stock.
Last edited by Dave concrete; 02-28-2015 at 02:14 PM. Reason: forgot to add something.
Just call me captain obvious.
All respect to you and your tuner.
