Anyone running Hoosier Radial on CCW Drag Pack?
Any info would be much appreciated. Thinking about running Hoosier D.O.T. Drag Radial 295/50-16 Tire 17326 on my rear 16" CCW drag pack. Currently have 28" bias Hoosier on them.
I run that tire, it works pretty well on a good prepped track. Still spins from a 60 roll a little on the street but it's the best tire I've had yet. Only thing I haven't tried is the 15" 275 PRO.
We run that tire as well and like it. I've also used it on 2 other cars prior to this one. As stated if the track prep is marginal a radial won't typically hook as well as a bias tire. However, the radial should MPH better on the top end because it doesn't grow.
Our best 60' is 1.50 and that's with 370 rwhp. The only time we tried nitrous (500 rwhp on a 100 shot and NANO) it blew the tires off instantly. We have a progressive controller on the car now but haven't been able to test it.
Very good tire IMHO.
Scott
Scott
Good track, these suckers hook. I'd say the only thing better would be the 275 Pros on 15s.
I run that setup. Leave on idle or a light foot brake to about 2k before it pushes through the brakes. As long as the psi is right (17-18psi) it does fine. If the psi creeps up past that it spins pretty bad just past the 60ft.
Never had them on the street though, I run a Mickey DR 345/18 on the street...which is basically useless, but damn fun!
i have had both, 275 pros hands down.
Not really what he was asking guys. We all know the 275pro is a better tire, but it only comes in the 15 inch size, and the cost to swap to that is not small.
- Travis
- Travis
Running 28" Hoosier bias tires now and have had good traction with half throttle launches. New RPM tranny in now and want to nail it off the line.
28 x 11.5 16" on CCW rim. I pull the inner fenders out and crank down the spring in the back to raise up the car as high it will go. Will work on getting a picture up for you.
I know this an old post. Just wanted to let you guys know I did not have any traction issues with the bias tires and the new set up. Also I ended up moving over to the Hoosier quick time 295 radial and hooked up with them as well.
- Travis
