Junkyard 5.3 build
Old 04-14-2015, 12:04 AM
JoeyG
JoeyG's Avatar
Cruise-In III Veteran
Cruise-In IV Veteran
If its an L33, it:s got the newer rods and 243/799 heads.
Old 04-14-2015, 02:27 PM
jimbos'ss
jimbos'ss's Avatar
It's an Lm4. Only made in 03-04.
Old 05-03-2015, 02:47 AM
jimbos'ss
jimbos'ss's Avatar
What's the consensus on ring gaps for boosted ls motors?Toying with the idea of putting in a set of wisecos and scat rods. I'll probably never push it past 800whp.
Old 05-03-2015, 05:26 AM
slow ride
slow ride's Avatar
Like I said before you can find some gen 4 junk for it cheap I'd bet. I wouldn't just drop nice Pistons in since you are not honing to fit etc. I'll check if my friend has any take out gen 4 stuff since he is a hoarder lol.
I'd take that gen 4 stuff to 800 with good gaps. I tend to follow weiscos chart for ring gap.
Old 05-03-2015, 10:58 PM
jimbos'ss
jimbos'ss's Avatar
I just found a set of brand new gen 4 rods for cheap. Gonna pick em up. Debating on going with the gm flat top pistons or finding some forged ones in that bore size that'll fit the stock gm wrist pin size. I'll probably just use a ball hone on the cylinders, you can still see the factory cross hatching.
Old 05-04-2015, 11:02 AM
slow ride
slow ride's Avatar
The thing is unless they are super cheap pistons I can't see doing a forged setup and not having control of a quality finish hone with a torque plate and using the head studs that will be on the engine. After talking to my friend he has 7 gen 4 rods/pistons (engine had a bad hole) but the bob weight on the crank will change and you will need a fresh balance on the gen 3 crank (sounds like it will take some heavy metal and that adds up also).
It's a hard call as I'm either all in or on the cheap and these parts will be somewhere in the middle for you. I'd probably do the Wiseco's for say something between a 5.3-5.7 engine (saving more cylinder wall) and pay for a quality finish hone/bore and balance work. It will be a stout piece at that point. Either that or stock flat tops with just some balance work and flex hone.
Old 05-04-2015, 09:41 PM
MVP'S ZO6
ISIS SUCKS FAT CHOAD
Support Corvetteforum!
MVP'S ZO6's Avatar
Mine are gaped at .024 on the top ring and .027 on the second ring. Weisco piston Hell Fire rings with a hooked Napier second ring.
Old 05-05-2015, 08:01 PM
skull
skull's Avatar
im doing a L33 bottom end s475 lil john cam and im suppose to be buying stage 2.5 ls6 heads from a friend. pump and meth. no intercooler. looking for 700. on e85 and meth im looking for 800+. run her for all it is worth lol. good luck and hope to see some pictures
Old 05-05-2015, 10:18 PM
jimbos'ss
jimbos'ss's Avatar
Thanks Mike!
basically when I'm finished it'll be an L33 rebuilt shortblock. I found a really good deal on the L33 flat tops. I haven't decided which heads i'm going with. I have my 243's which should put me at 9.9:1 or I could use the 317's I have and run it at 9.3:1. And I could mill the 317's and get it up to 9.5:1 which is what I want.
Old 05-05-2015, 10:33 PM
slow ride
slow ride's Avatar
Good deal on the parts. It's a little much to not have balanced though.
Old 05-05-2015, 11:49 PM
jimbos'ss
jimbos'ss's Avatar
I'll definitely pay to have the rotating assembly balanced. I figure I have to since the pistons and rods will weigh more than the ones that came in the motor and the crank is originally balanced to those.
Old 05-06-2015, 08:48 AM
slow ride
slow ride's Avatar
Cool just checking This will be a nice solid combo with the proper ring gap. The reduced displacement is probably a better fit to your turbos also. Have you ever measured your exhaust wheel or know the turbine housing size by chance?
Old 05-06-2015, 02:49 PM
  #33
junk c5
junk c5's Avatar
If you are going to take the Pistons out for any reason, I would send them out to be coated. I had my brand new diamond Pistons coated in my motor for the added extra protection.
Old 05-06-2015, 04:37 PM
  #34
schpenxel
schpenxel's Avatar
Received 1,194 Likes on 1,053 Posts
St. Jude Donor '15
At some point you have to draw the line and say this is a JUNKYARD build.. and not let the price get out of control, if a junkyard build is really what you want.
Old 05-06-2015, 05:12 PM
  #35
jimbos'ss
jimbos'ss's Avatar
Just adding stock gen 4 pistons and rods to it and a good balance. I'll still be under the cost of a used L33 after I sell off all my spare parts.
Old 05-06-2015, 05:20 PM
  #36
schpenxel
schpenxel's Avatar
St. Jude Donor '15
Default Junkyard 5.3 build
That was more in response to the coating idea
Old 05-06-2015, 07:02 PM
  #37
jimbos'ss
jimbos'ss's Avatar
oops
To Junkyard 5.3 build
Old 05-06-2015, 08:54 PM
  #38
schpenxel
schpenxel's Avatar
St. Jude Donor '15
oops
haha, it's cool
I only say that because I've let a build on another car go overboard by what I call the NASA syndrome. You want to make sure x doesn't break, so you spend a little more money on it, then you have more money invested so you want to be really sure y doesn't break.. then you have more money in it, so you want to be really sure z is good enough too, and somewhere along the way you've tripled your budget, lol.. you get the idea
Sounds like you've got it under control. I'm looking forward to seeing it.. it's amazing what people have been getting out of "junkyard" builds on ls1tech
Old 05-06-2015, 10:07 PM
  #39
jimbos'ss
jimbos'ss's Avatar
I'm all too familiar with that story.
I'm hoping too avoid going down that road. I already have concerns about the drivetrain living at the current power level.
Old 11-29-2015, 06:34 PM
  #40
jimbos'ss
jimbos'ss's Avatar
Finally started making progress on this build since my ls6 is hurt.
Specs:
New Gen 4 rods
Flat tops
New rings gapped for boost
Ls7 lifters
Ls2 trays
Clevite bearings
BTR dual springs
317 heads
Ls9 head gaskets
Selling oil pump.
Head studs
I'll be having the pistons, rods and crank cryoed.
Quick Reply: Junkyard 5.3 build
