direct meth injection
I'd like to do port meth injection instead of the dual nozzles in the up pipe for better distribution.
I'm a bit afraid of tapping the stock intake and drilling it and considering after market intakes that would be like a hogans or wilsons without the sky high price. looking to pay 800 or less
any recommendations? I'm also looking to stay under the hood on a c5 stinger hood.
I've looked at the polished low profile stock ls6 style but I'm interested in alternatives.
tia for any advice!
tia for any advice!
Someone else I am sure will chime in but I have had hogan manifolds in the past and they are a work of art. I have never seen a custom intake manifold for around that price but then again I have never looked that close just went with what I knew. I am curious to see what is out there as well.
Supporting Vendor
Fast, Cheap, Reliable....Pick any 2, because 3 ain't gonna happen.
__________________
Offering products from A&A Superchargers, East Coast Superchargers, Mechman Alternators, Mantic clutches, RPS clutches, Kooks Headers, Lakewood, LG, Brian Tooley Racing, Comp Cams, FAST, ARP, UPP Turbo systems, Wiseco, Callies, K1, MAST Motorsports, Haltech and many more. PM me for details.
Supporting Vendor
I can get you setup with a direct port meth setup. We tap and drill stock intakes all the time.
Check out this C7 with Direct port meth/nitrous.
https://www.corvetteforum.com/forums...-methanol.html
PM me if interested and want a price.
Billy
Billy
Billy
Billy
Here are some thoughts and arguments that I've had with myself over various ideas on meth injection systems.
I've seen so many arguments over using water over meth with comments like "water has infinite octane" and "water removes more latent heat than methanol".
While that may be true, there are two major considerations for those statements, the first being that for octane to be a consideration for me, it needs to be able to burn. Granite may have infinite octane too, but I won't be spraying it in my motor.
The second major consideration for removing heat is that it needs time to change phase because without changing phases, it doesn't remove any heat. Direct port injection takes away a lot of that time, but it does solve the issue of equal distribution. With ample time to change phase, you don't have to worry about distribution. Once it's a gas, it is distributed as equally as the air. For these reasons, I considered not only doing a direct port system, but a system with a few stages. One before the blower, one after, but pre intercooler, one post intercooler and one direct port. The stages wouldn't have to be high volume or anything. The only drawback to doing all these stages pre-throttle-body is that if anything ever ignited that mixture, you would have quite a show on your hands.
I never have understood the mystery behind direct port methanol injection and why no one has had success with it. There are cars that run straight methanol with carburetors and even racers that run fuel injectors using 100% meth. Why can't it work in a direct port application?
it does. no big mystery. hell I ran a flying toilet mechanical injetion system and it works just fine.
mr lee put one on his blower car and saw the egt variance go from 300 deg to less than 100 without tuning the specific jets
the meth doesn't like the ls6 style intake under more heavy injection as distribution isn't all that great
direct port fixes that. I found a low provile alum intake with bosses cast in that looks perfect for my needs and it's polished for a bit of bling and comes with fuel rails.
I also saw some great deals on mini ram intakes but I'm not as confident in the quality.
like to use braided lines and setup the jets to even out the EGTs
should work just fine. monitoring and tuning I think will be the key
Direct port meth should work fine, the only downsides I see to it are:
1) Mix time with the air charge and meth are minimal when injecting the meth straight into the port, so you may not get as much reduction in charge temps.
2) In conjunction with #1, spraying the meth in down stream from the IAT sensor isn't going to "show" the reduced IATs to the PCM, (sense the sensor isn't getting sprayed with meth) therefore it's still going to see higher IATs and likely reduce timing, thus killing power that it doesn't need to.
Just my thoughts as an amateur.
There is a local guy down here with a C7, maxed P1SC that supposedly makes 900rwhp and it has the NX direct port meth on it. I looked at the meth kit and it is a pretty trick piece. This guy beats on this car pretty good, 900rwhp (if you can believe it) on the stock LT4 (well, H/C/E) and it's staying together.
direct port meth
for sure direct port reduces the cyl to cyl EGT variations and as Kenny D. put's it. give each cyl what it wants and needs to balance A/F ratios and EGTs and you'll have a smoother more durable engine.
makes sense to me, now I need to sell something so I can afford that haltech S2000 install!!! thinking about uprading to the latest version if I can afford it as it has new traction control and drive by wire that seem to be a great way to go on an over powered street beast.
with the fancy Haltech controlling the pump (with a high amp driver box that I already have) I can also bump timing up anytime I'm spraying meth.
I'm looking to potentially have a "heavy meth dependent tune" as the Haltech will have the control nannies to chop the boost and pull timing anytime the EGTS or A/F ratio get too far out of whack"
like to install all this "stuff" at the same time and include it in the tuning to make sure I get it right the first time. Mr. Lee has done some of the hard work and R&D on high HP blown cars and proved it's worth to me.
I'm going to price out the NX and the ECS solutions and see how they stack up. I was good friends with old John S. (RIP). That guy was indeed a crazy genius and alot of fun to hang out with. He had some pretty cool ZR-1s on the jug which has always been tempting, but I'll stick with boost over "chemical boost" as I'm a turbo fiend.
the traction control and boost by speed properly blended should improve consistency of ETs of a turbo car at the track too! from my experience racing turbo buicks, they were easy to make fast, but hard to run the number consistently as the air changes, HP varies quite a bit!
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,086 Likes
We done several direct port kits on custom builds, the distribution is much better. We do not sell-make-or offer these for sale, but you can use this picture as something to work off of.
__________________
C5/C6 and C7 Supercharging Specialist
ECS Supercharger Kits / Mantic Clutches
www.EastCoastSupercharging.com
Facebook Page
ECS YouTube Channel
Facebook Page
ECS YouTube Channel
Received 1,194 Likes
St. Jude Donor '15
That looks like something NASA would build, lol.
All this talk about direct meth injection, EGT's, even distribution, aftermarket ECU's and so on makes me wonder why engines break...
...isn't it all about the tune? :-)
I'll get me coat.
I'll get me coat.
I'll get me coat.
Fast Show - I'll Get Me Coat - YouTube
I'll get me coat.
even the best build will break in short order if the tune isn't right.
and the aftermarket stuff has some nice processing speed and "alert driven" safety nannies to hopefully catch problems before the damage is too severe.
I'm not pushing the LS architecture all that hard, but I'd like to do it once and not have to do it over for a while!
