rwhp/trq estimates with new setup
Old 07-10-2015, 09:49 AM
jmd1487
jmd1487's Avatar
Default rwhp/trq estimates with new setup
just finished up a new setup with my 03 Z06, it now has an A&A v2si with 3.4 pulley, alky meth, A&A 220/230 small blower cam and kooks 1 7/8 headers no cats and corsa extreme . Just looking for some thoughts as to what kind of power this setup should put down.
Old 07-10-2015, 10:23 AM
donald4972
Support Corvetteforum!
donald4972's Avatar
St. Jude Donor '14-'15
You'll get 550 without the cam/meth. I'd guess you'd be somewhere north of 575 RWHP. Depends on the tune, agressive or mild, also. The Meth allows lots of leeway on the tune.
One thing for sure; you will love it!!!
Be careful, at first, until you get used to what you have....
Traction control is your friend!!!
Be sure to post real numbers when you get them.
Don
Old 07-10-2015, 10:36 AM
jmd1487
jmd1487's Avatar
I would like to see 650ish at the wheel, boost level should be around 11-12psi. I have 305 toyo r888 so it will still spin but should hook by 3rd gear lol. Its at the tuner now but he has to fab up a new charge pipe to accommodate the Tial BOV, so it should be done next week
Old 07-10-2015, 10:59 AM
nullpointer
nullpointer's Avatar
I would like to see 650ish at the wheel, boost level should be around 11-12psi. I have 305 toyo r888 so it will still spin but should hook by 3rd gear lol. Its at the tuner now but he has to fab up a new charge pipe to accommodate the Tail BOV, so it should be done next week
What type of dyno do you want those numbers on?
I am at ~13 psi, ported heads, cam, headers, meth, sd tuned and on a mustang dyno I was ~650 rwhp. Mind you the Dynojet numbers are 740s, so you can see why I ask.
Old 07-10-2015, 11:11 AM
jmd1487
jmd1487's Avatar
It will be on a dynojet
Old 07-10-2015, 11:31 AM
nullpointer
You should be good for your target, hope the R888s work for you. At my power level they spin at the top but I never got to try them on a nice 80* day.
Old 07-10-2015, 11:56 AM
jmd1487
jmd1487's Avatar
Good to know thanks, what kind of torque number should I see?
Old 07-10-2015, 02:03 PM
nullpointer
Purely based on my results, I would say ~100 less than your peak HP. Now that can change with your cam, headers, etc. Grain of salt
Also depends on timing and tune.
Old 07-10-2015, 02:31 PM
tlove32
tlove32's Avatar
I made 640rwhp / 569rwtq with very similar setup (I had 228/232 cam)
Old 07-10-2015, 04:16 PM
jmd1487
jmd1487's Avatar
wow very good torque for a stock ls6, I will be very happy with that number. I will have dyno numbers late next week...
Old 07-13-2015, 07:13 AM
madmatt9471
madmatt9471's Avatar
Location: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
You'll make nice power - but just don't get caught up in the numbers let it give you what it gives you! and make adjustment from there
Ohh and it'll give you some nice smells with no cats too!
Thanks,Matt
Old 07-16-2015, 11:33 AM
nstyzo6
nstyzo6's Avatar
I have similar set up also with the exception of meth...but I am running e85 and I Just made 660rwhp and 580tq on 10lbs. I wan to add methanol kit now.
Old 07-16-2015, 11:57 AM
skydiven4fun
skydiven4fun's Avatar
St. Jude Donor '13-'14-'15
With a good tuner you should be there I would think, My LS1 is just under 650 set up almost the same, different cam but that's basically it.
Old 07-16-2015, 05:45 PM
jmd1487
jmd1487's Avatar
shop just finished making a custom charge pipe to hold the tial BOV/meth nozzle and there installing the alky meth kit tonight, should have dyno numbers tomorrow...
Old 07-17-2015, 05:43 PM
jmd1487
jmd1487's Avatar
well the numbers are in and im at 655rwhp and 561rwtq at 12psi, very satisfied with the numbers, cant wait to pick it up tomorrow
Old 07-18-2015, 08:21 PM
jmd1487
jmd1487's Avatar
Picked up the car and all is well, however when I let off and coast down the road and then accelerate again I get a lean reading and surge for a couple seconds, long story short it appears that my tial bov is not opening at idle and building up air until I hit the throttle, unsure as to what spring is in the bov but I will be taking off tomorrow to check the color, has anyone else had this problem?
Old 07-20-2015, 12:16 PM
PEETYZ
PEETYZ's Avatar
Nice numbers!
Never had that problem with my Tial Q on old set up. Check the spring and the vacuum lines then report back.
To rwhp/trq estimates with new setup
Old 07-20-2015, 04:06 PM
jmd1487
jmd1487's Avatar
It's an unpainted spring that is currently in there, I have a extra black and green spring, which one should be in there? The vacuum line is tied into a T with the boost gauge
Old 07-20-2015, 04:50 PM
skydiven4fun
Minor issues to deal with, sweet numbers and definitely going to be a lot of fun.
You'll definitely enjoy it, when you have a car like this it's a labor of love for sure, that's what makes it so much fun.
Old 07-21-2015, 05:36 PM
jmd1487
jmd1487's Avatar
Well I switched out the spring to the 3lb and yes now it is open at idle. However it still have drivability problems so I dropped it off to the tuner and he said I need to switch to a speed density tune... So I left it with him ugh more money lol
Quick Reply: rwhp/trq estimates with new setup
