**C5 High Horse Power Club**
Veteran
1997 Corvette A4
580 HP/ 509 TQ
346ci Forged bottom end
A & A Vortech V3 Si with Alkycontrol Meth
Kooks headers w Borla Stingers
Performabuilt level 3 trans
Z06 3.42 diff
580/509
580 HP/ 509 TQ
Z06 3.42 diff
580/509
2004 Z16 ZO6
709 WHP / 567 WTQ @ 13 PSI
347ci Fully built bottom end by AMT Racing Engines
Custom Grind blower cam
A & A Vortech V3 T Trim with Alky Control Meth (30% mix), 93 octane MAF tune
AR 1 7/8" long tubes with catted X pipe, Halltech filter
ID 850 injectors
ID 850 injectors
346ci LPE twin turbo forged LS6 block
8.75 compression
700rwh on 15-16lbs of boost with Speed Density tune.
Mix of 93 and 100 octane on high boost
Best ET of 9.94 @ 139.69mph with a 1.643 60 ft. On 315/30/18 Hoosiers
8.75 compression
Jason Blue Boost (12-29-2015)
#33
02 tt z06: 726 / 682
Forged 408 Stroker
318 Ported Heads
1 7/8" Headers Full Exhaust X Pipe
78# Injectors
Methanol Injection
Twin STS Turbo's @ 10.5lbs boost
Stage 5 RPM Trans. w bracing
Currently waiting on Delivery of my: "Mantic TWIN DISK Clutch" do to ITEMS listed ABOVE!
318 Ported Heads
78# Injectors
Methanol Injection
#35
1999 Corvette, 481 LSX Tall Deck, F2 Procharged, 16.8 PSI
1,400 HP
Bandimere Speedway 7,800 Air Density Altitude.........
Best ET 2015 8.85 @ 156.6 MPH.
Built by Corvette Connection Denver
1,400 HP
#37
1,400 Motor. 5,400 Flash Stall Converter is eating some HP, but we calculate Planting 1,228 to the Tire. We are fighting traction Issues, so we are Dumping Boost. Motor is built for 25 PSI, so running 16.8 we have a bit to go. Going to a 15" wheel and a 29" tire this season. Should be able to screw in some more Boost and run right in the Chassis Cert which is 8.50 @ 162 MPH. "Street Legal" and Cruzin the Street when ever possible!!!
Rich
Rich
#40
St. Jude Donor '15-'16-'17-'18
1,400 HP
https://youtu.be/dsz5smYh2hk
1,400 HP
