will vortech make a blower like a F1x? YSI isn't enough!!
Old 01-24-2016, 05:08 PM
master blaster
master blaster's Avatar
Default will vortech make a blower like a F1x? YSI isn't enough!!
My YSI is maxed out and i am thinking of going with a procharger F1X.
It would be great if i could still use my 10 rib vortech parts...A&A system and just buy a bigger head unit?
Do you think vortech will be making a similar head unit?
Old 01-24-2016, 05:21 PM
CamminC5
Support Corvetteforum!
CamminC5's Avatar
St. Jude Donor '15-'16-'17-'18
won't a V4-X;XX;or Z work?
Old 01-25-2016, 06:30 AM
stevieturbo
stevieturbo's Avatar
If you're actually contemplating something as large as the X, then clearly the V7 XB110 would be the Vortech you'd want and it will fit the YSi brackets...if there is enough room for the volute elsewhere which is unlikely. Although I thought years ago Andy was trying it ?
I asked Vortech many many times for an upgrade to the YSI, they always said no too.
Eventually the huge XB110 came out and I asked for something in between, say a V7 XB105...they said no. I had asked for years for a billet impeller for the YSi, eventually this appeared....and seems to largely be a damp squid.
So I changed to turbos instead.
Old 01-25-2016, 06:32 AM
stevieturbo
Or as Cammin says, the V4's can fit the same brackets even if they also have provision for another row of bolts. Although it may not apply to all bracket systems.
I just couldnt bring myself to spend all that money on yet another ancient cast wheel blower even if it probably would have performed great.
I nearly bought one second hand though...but opted for turbos instead
Old 01-27-2016, 05:29 AM
c5mtl
c5mtl's Avatar
I'm in the exact same spot as you are...I've been reading a lot on yellow bullet and guys that made the swap to the billet impeller on the ysi are picking up big numbers...I'm not sure why the consensus over here is no gains or maybe same gains up top and losses down low..most report a 2-3psi gain down low and big gains above the 65000 so called max impeller speed. I also wonder if thebillet wheel raises the max impeller speed.
Some results
trans break 5,200 rpm
cast 13.6
billet 15.9
51,129 imp rpm
8,300 rpm at trap
cast 32.2
billet 38.3
81,609 imp rpm
there ya go
Old 01-27-2016, 02:01 PM
stevieturbo
I think that's 1 person so far who has reported a solid gain in performance.
The rest....still waiting.
Old 01-27-2016, 03:20 PM
DOUG @ ECS
Premium Supporting Vendor
DOUG @ ECS's Avatar
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,086 Likes on 657 Posts
We have seen gains, not as much as what was listed above, but solid gains.
Old 01-27-2016, 11:33 PM
MVP'S ZO6
ISIS SUCKS FAT CHOAD
MVP'S ZO6's Avatar
Put a pair of exhaust driven blowers on your car! :-)
Old 01-28-2016, 05:02 AM
stevieturbo
That's the thing, the post above just implied a boost gain, as do some other threads.
Few actually seem to report any power or performance gain.
Certainly not what would have been hoped..and certainly makes it difficult to justify swapping.
Something like a V7 XB105 would be a perfect upgrade and could be physically a lot smaller than the 110.
I don't even think I've seen any reports of anyone using a 110 either though ?
Old 01-28-2016, 11:42 AM
algZO6
algZO6's Avatar
that same guy also picked up .29 seconds with no other changes, not even tuning
Old 01-28-2016, 01:06 PM
robert miller
robert miller's Avatar
Received 1,762 Likes on 1,529 Posts
Default ttt
To really gain to close to the max that the F1X will do I hope you have a good cam to get the cost over the YSI. I went from a 402ci ls2 block YSI set up. To a RHS 427ci set up with about the same cam also went from a TF 225 head to a TF 245 head and didn't gain the cost of every thing at all.
But I did like the way the F1X came in on the car over the YSI. F1X comes in higher up in the RPM range plus a lot harder when it did.
I was told it was my cam holding the car back just wasn't big enough to get the FULL out of the F1X head unit.. Robert
Old 01-31-2016, 01:09 AM
c5mtl
c5mtl's Avatar
How small is your cam?? I'm in the 239/254 range
Old 02-02-2016, 04:10 PM
0Rob@ChampionMotors
Former Vendor
Rob@ChampionMotors's Avatar
Our cam has the same Duration
c5mtl (02-03-2016)
To will vortech make a blower like a F1x? YSI isn't enough!!
Quick Reply: will vortech make a blower like a F1x? YSI isn't enough!!
