NOS Mini Progressive Controller Help
Finally got everything installed on my 02 z and wanted to do a few test hits on a small spray. Well, I had the bottle on, controller on, purged the line, and did a pull. absolutely nothing happened. Here's what I currently have it set up to. (This is on an LS1/6 NOS Plate kit)
F (frequency) set to 15
C - 00
P - 00
Activation - 30
Deactivation - 60
Delay - 0.0
Start % 99
(5) ramp rate 1.0
(6) end % - 99
(7) 0.0
(8) TPAS - 02
(9) TPS - 4.7
only running a single stage one channel at this point
C - 00
P - 00
Activation - 30
Deactivation - 60
Delay - 0.0
Start % 99
(5) ramp rate 1.0
(6) end % - 99
(7) 0.0
(8) TPAS - 02
(9) TPS - 4.7
Former Vendor
Also, try lowering your TPS activation to 4.3 volts. Even though WOT with the key on and motor off may be around 4.7, it rarely hits that once the car is actually running. 4.2-4.3 will give it a place where it can hit and see steady voltage.
-Andy
-Andy
I'll give that a shot. That's currently tapped into the dark blue wire comping off the tps signal.
just set it to 4.1 and went out for another hit and still no luck.
I don't have a bottle pressure gauge yet but it's a fully filled bottle. I have the power portion of my solenoids going to the relay and the ground to the controller
In the past, I've heated bottles higher than recommended causing the nitrous not to flow. But the fuel should still come on enough to lug the motor down. The telltale sign that your bottle is too hot is you cannot purge prior to making a pass.
I believe we target 1000 psi then purge it down to 950 ish before making a pass. We use a 250 hp shot on my buddies SBC.
