Dyno Numbers - Stock (Intake Only) vs ATI P1SC vs Magnuson on LS-1 C5
Old 09-17-2002, 05:39 PM
R6_C5_CLS55
R6_C5_CLS55's Avatar
Default Dyno - Stock vs ATI P1SC vs Magnuson on LS-1 C5 vs 62-1 Single Turbo on '01 LS6
I have been putting together some HP and torque tables of data and I thought some of you might be interested. The stock and ATI data was taken straight from my own dyno curves. The stock curves data comes from a curve generated at MTI, and the ATI data comes from a curve generated at Ed Wright Automotive (Fastchip). The Magnuson data was read froma dyno curve supplied by another CF member.
Stock (MTI True Ram Air only mod)
RPM HP Torque
2600 156 320
3000 185 322
3500 220 330
4000 259 338
4300 276 338
4500 290 339
5000 320 337
5225 325 325
5500 330 313
6000 320 280
ATI P-1SC w/ FLP LT's
RPM HP Torque
2600 180 360
3000 220 383
3500 277 412
4000 335 442
4300 358 445
4500 390 455
5000 442 462
5225 458 458
5500 470 448
6000 498 433
6200 508 426
ATI P-1SC Compared to Stock
RPM Delta HP Delta Torque
2600 24 40
3000 35 61
3500 57 82
4000 76 104
4300 82 107
4500 100 116
5000 122 125
5225 133 133
5500 140 135
6000 178 153
Magnusson SC w/ Cold Air Intake
RPM HP Torque
2600 185 380
3000 220 385
3500 270 395
4000 305 400
4300 335 400
4500 340 390
5000 375 390
5225 380 385
5500 400 380
6000 410 360
6200 415 355
Magnuson Compared to Stock
2600 29 60
3000 35 63
3500 50 65
4000 46 62
4300 59 62
4500 50 51
5000 55 53
5225 55 60
5500 70 67
6000 90 80
Magnuson Compared to ATI P-1SC
2600 5 20
3000 0 2
3500 -7 -17
4000 -30 -42
4300 -23 -45
4500 -50 -65
5000 -67 -72
5225 -78 -73
5500 -70 -68
6000 -88 -73
6200 -93 -71
LS-6 with 62-1 Single Turbo
RPM HP Torque
2600 135 275
3000 235 405
3500 290 437
4000 370 480
4300 400 485
4500 415 480
5000 440 470
5225 445 450
5500 452 430
6000 440 385
6200 385 335
62-1 Single Turbo on LS-6 (5 PSI) Compared to ATI LS-1 (7 PSI)
2600 -45 -85
3000 15 22
3500 13 25
4000 35 38
4300 42 40
4500 25 25
5000 -2 8
5225 -13 -8
5500 -18 -18
6000 -58 -48
6200 -123 -91
[Modified by R6_C5_ML430, 8:56 PM 9/17/2002]
Old 09-17-2002, 06:03 PM
C5Noir
C5Noir's Avatar
Default Re: Dyno Numbers - Stock (Intake Only) vs ATI P1SC vs Magnuson on LS-1 C5 (R6_C5_ML430)
Based on these results what are the pros/cons of the ATI vs Magnuson?
Old 09-17-2002, 06:38 PM
Crushinator
Crushinator's Avatar
Default Re: Dyno Numbers - Stock (C5Noir)
I'd say that one of the pro's to the ATI is that it gobs more power than the Magnuson. :cheers:
Old 09-17-2002, 07:21 PM
Mad_Dog
Mad_Dog's Avatar
Cruise-In II Veteran
Cruise-In III Veteran
Thanks for taking the time to put together the numbers -- confirms what I had believed all along. That is part of why I went with ATI.:D:D
Old 09-17-2002, 10:06 PM
ZZ
ZZ's Avatar
Cruise-In I Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VII Veteran
Sean, thanks for that comparison, very nice. I anticipated the ATI would see an advantage at higher rpms, but it surprised me a bit the Magnusson did not see a bigger advantage down low and more instantaneously.
ZZ
Old 09-17-2002, 11:01 PM
R6_C5_CLS55
Default Re: Dyno Numbers - Stock (ZZ)
I added some additional data in my original post that I found on the 62-1 Single Turbo set-up on a '01 LS-6 motor at 5 PSI and ran a comparison between it and the ATI P-1SC kit on the LS-1 at 7 PSI.
Old 09-18-2002, 10:22 AM
vetterdstr
vetterdstr's Avatar
CA Events Coordinator
ZZ
I agree, this is what I was looking for too. :yesnod: looks like the ATI unit is a good one.
vetterdstr :cheers:
Old 09-18-2002, 12:40 PM
indyblue98
indyblue98's Avatar
Default Re: Dyno - Stock vs ATI P1SC vs Magnuson on LS-1 C5 vs 62-1 Single Turbo on '01 LS6 (R6_C5_ML430)
Great post to see side by side results. To take it one step further.
T62-1 with 7 lbs boost vs ATI with 7 lbs boost
Rpm hp torque hp torque
2600 135 280 -45 -80
3000 230 390 +10 +7
3500 300 450 +23 +38
4000 375 485 +40 +43
4500 430 510 +40 +43
5000 480 520 +38 +62
5200 500 500 +42 +42
5500 ***************************
6000 ***************************
no data above 5200 for 7lbs boost T62-1
:seeya
Old 09-18-2002, 03:39 PM
Earl H
Earl H's Avatar
Default Re: Dyno - Stock vs ATI P1SC vs Magnuson on LS-1 C5 vs 62-1 Single Turbo on '01 LS6 (indyblue98)
I was waiting to see an apples to apples comparison...
Old 09-18-2002, 09:01 PM
R6_C5_CLS55
See below.
[Modified by R6_C5_ML430, 7:17 PM 9/18/2002]
Old 09-18-2002, 09:15 PM
R6_C5_CLS55
I found that data too, but wanted to get a full curve before posting it as the T62 drops off after 5200 and the ATI keeps increasing until fuel cut.
Are the numbers you posted for a '01 or '02 Z06? The '01 and '02 Z06 LS6 has 35 and 55 more crank HP respectively than the LS1 that I posted the ATI numbers for, so subtract ~30 RWHP from your numbers if it was from a '01 LS6 and ~47 RWHP from your numbers if it was from a '02 LS6.
Also, I want to get a curve for an ATI with a D1SC on a Z06 and compare with the 62-1 data as the 62-1 data generated to date is on a Z06 / LS-6 and the ATI numbers I have are on a LS-1. I figured the LS1 with ATI @ 7 psi compared to a LS6 with 62-1 at 5 psi was not that far off from an apples to apples because of the offset between the stock HP engine numbers vs the 2 PSI of boost.
If anyone has full curves for:
1. Stock '01 or '02 LS6 with ATI D1SC and LT headers
2. Stock LS1 with ATI D1SC and LT headers
3. Stock '01 or '02 LS6 with 62-1 Single Turbo
4. Stock LS1 with Vortech kit and LT headers
5. Stock LS6 with Vortech kit and LT headers
PLEASE POST THEM!
Old 09-18-2002, 09:28 PM
TCSF
TCSF's Avatar
What PSI was the Magnuson generating?
Old 09-18-2002, 10:09 PM
Av8ter
Av8ter's Avatar
im not sure how ot post graphs but here are a couple of links with graphs in them that should have what youre looking for.
http://forums.corvetteforum.com/zerothread?id=381324
http://forums.corvetteforum.com/zerothread?id=354527
Old 09-18-2002, 11:06 PM
Devil Dog
Devil Dog's Avatar
If these dyno numbers are not same day,same dyno,and same car they are pretty much useless. :nono:
Old 09-18-2002, 11:23 PM
R6_C5_CLS55
Default Re: Dyno - Stock vs ATI P1SC vs Magnuson on LS-1 C5 vs 62-1 Single Turbo on '01 LS6 (Devil Dog)
TCSF - I think the Magnuson was putting out 5 PSI, but I am not 100% sure.
AV8TER - Thanks for the information. I will make another table comparing the '02 Z06 with ATI D-1SC and LT's with the 62-1 single turbo at 7 PSI if I can get a complete chart on the 62-1.
Devil Dog - It will be impossible to ever get dyno charts for all of these FI systems on the same car on the same day on the same dyno. :confused: I guess we'll never be able to compare different supercharged applications to one another and to turbo applications. :rolleyes: I think most stock cars of the same make and model are within 2 - 3 % of one another in terms of HP. The fact that the dyno numbers are SAE corrected is the best we can do to take into account differences in temperature, barometric pressure, humidity, etc. I think is is reasonable to make these comparisons. How do you propose that the comparisons should be made?
Old 09-19-2002, 12:15 AM
Av8ter
Av8ter's Avatar
As far as I know, this is the only full graph showing the 62-1 turbo going to redline, or at least beyond 5300 rpm,,,,not the first dyno but the second one below it
http://forums.corvetteforum.com/zero...=380003&page=3
[Modified by Av8ter, 10:16 PM 9/18/2002]
Old 09-19-2002, 12:42 AM
MelloYellow
MelloYellow's Avatar
Default Re: Dyno - Stock vs ATI P1SC vs Magnuson on LS-1 C5 vs 62-1 Single Turbo on '01 LS6 (Av8ter)
Good post.
Also consider the 62-1 at 8psi, 9psi, 10psi
as well as the T72 at 7,8,9,10+ shortly for higher rpm setups.
To Dyno Numbers - Stock (Intake Only) vs ATI P1SC vs Magnuson on LS-1 C5
Old 09-19-2002, 06:32 PM
TCSF
TCSF's Avatar
I would think that if the Magnuson was only putting out 5 PSI, versus 7 for the ATI, it is premature to come to any conclusions.
Old 09-19-2002, 08:35 PM
ED Brantley
Support Corvetteforum!
ED Brantley's Avatar
Default Re: Dyno Numbers - Stock (QuickSilver97)
Where did you locate the 4:10's at?
Old 09-19-2002, 09:03 PM
R6_C5_CLS55
Default Re: Dyno - Stock vs ATI P1SC vs Magnuson on LS-1 C5 vs 62-1 Single Turbo on '01 LS6 (TCSF)
TCSF - Since the Magnuson is not intercooled, with the stock CR of the LS1 and LS6, I am not sure if you can safely run more than 5 PSI on pump gas. If you can run more boost, its not much.
Quick Reply: Dyno Numbers - Stock (Intake Only) vs ATI P1SC vs Magnuson on LS-1 C5
