Concerns on in tank setup
Old 01-16-2017, 09:59 PM
mykream
mykream's Avatar
Default Concerns on in tank setup
Hey guys,
Planning on doing hci on my 2002 c5z, fuel is my first concern and how I need to go about it. I'd like to use a single Walbro 400,450, 485...etc. I read so many posts saying that it can be done, which I know it can.. But the last thing I want is to have to worry about the pump running out of fuel under a 1/4 tank or during any hard turns/acceleration/deceleration.
So what needs done exactly? Is there anyway around this?
Thanks for any/all responses.
Old 01-16-2017, 10:14 PM
Smoken1
Support Corvetteforum!
Smoken1's Avatar
I really see no need for a pump that big just for a H/C/I set up.. If you are that worried look into this...
http://www.lingenfelter.com/product/...l#.WH2LIbmP308
Old 01-16-2017, 10:15 PM
mykream
mykream's Avatar
Sorry, forgot to mention the car will have a plate on it running a 150-175 shot of sauce...
Old 01-16-2017, 10:28 PM
Smoken1
Smoken1's Avatar
Ok I nave no idea on what is needed for NOx.. I'm just doing a D1sc blower set up.
I'm sure others will chime in
Old 01-16-2017, 10:30 PM
mykream
mykream's Avatar
Most likely, thanks anyway
Old 01-16-2017, 11:27 PM
mykream
mykream's Avatar
I think I actually found a viable solution. Radium makes a venturi pump. Would be easy to set up. Mount it in or on top of the bucket, run the return line from the fpr to the top port, run the feed line for the passenger tank into the other feed to complete the siphon and have the exit dump into the bucket to keep it full so the bucket doesn't run dry.
http://www.radiumauto.com/Venturi-Jet-Pump-Kit-P760.aspx
To Concerns on in tank setup
Quick Reply: Concerns on in tank setup
