ATI rpm and boost
ATI rpm and boost
I am considering an ATI setup, but, I would like to get more info, what rpm does boost kick, does it build slowly from 0psi to 7 psi or higher or does it hit full boost imedeiately. Thanks for any input.
Re: ATI rpm and boost (nosturbo)
Get Andy's single ic kit and bracket/pulley setup. It will save you alot later. He had them on sale. You are close enough to let him do the install/tune too.
The boost will start at 3500 and will jump to about 5psi and climb. Do at least a cam with it so it can go up to redline with it.
Supporting Vendor
1 Post
Re: ATI rpm and boost (blown in n.c.)
Boost will come on linearly, it won't start at 5psi and climb. On a 7psi setup you usually won't hit 5psi until around 5K RPM.
I see boost starting at about 3000 rpm and goes to 13lbs at 6400 rpm. this is with the 3.85 pulley. I am also runnig sy3500, and 3.73's. This is andy's kit in my opion the only way to go.
[Modified by esram, 3:36 PM 3/6/2004]
Re: ATI rpm and boost (esram)
Got alot more than just the blower. I have 3.73s too and the boost jumps to 5psi when you get on it and then it will rise slowly to you top boost. It makes less # boost at other times, but when you nail it, you get it all at once.
