LED Tail Light Upgrade.
Hello Everyone,
I just completed the LED Tail Light upgrade that was originally posted by MyVetteDream in the following post: LED tails ... Dial Up Warning.
First I want to thank MyVetteDream for the original post and for the links to the website to purchase the LED bulbs.
MyVetteDream has the Euro Tail Lights so his installation was a bit different than mine since I have the stock Tail Lights.
**The reason for my post is to explain how to do the upgrade to LED's with the stock Tail Lights.
I purchased the bulbs from superlumination. ***For some reason the website that MyVetteDream gave us (autolumination.com) is no longer working but the link that I listed here is the one that they gave me in their email when I ordered the bulbs.
Here is a link to the installation page they provide: Installation
1) You need Four bulbs (3157 Red) go to this link: 3157 Bulbs and scroll down to the "Light Tower" bulbs and order the "3157 Red" bulbs.
2) You also need Four "Load Equalizers". Click on this link Load Equalizers and order Four 6 OHM Equalizers.
3) The Load Equalizers simulate the resistance of the stock bulbs so the turn signals do not flash real fast after installing the LED's.
I really like the way the lights come on instantly now just like the 3rd brake light does. If you guys need any help doing the installation just let me know and I will walk you through it
Here is a picture of the bulbs:
Originally Posted by Vette-Pilot
Hello Everyone,
1) You need Four bulbs (3157 Red) go to this link: 3157 Bulbs and scroll down until you find the "3157 Red" bulbs.
Thanks for the post, but which 3157 red bulbs did you get?
24 LED, 19 LED, etc.?
...George
Location: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Thanks for the update Jack
I've been wanting to do my turn signals and trying to figure out what would work. Sounds like you found a good answer
The website you listed works great! Thanks.
I love this place!
Dave Q.
I love this place!
Dave Q.
Location: Lino Lakes, MN _________________________ I Figured out how to do this!
Have you tried your emergency flashers to see if any codes were thrown?
...George
...George
Sorry but I forgot to specify which 3157 Red Bulb :o I have edited my first post to specify which bulb
Order the 20 LED Light Tower shown here:
ok pleae walk me through it -------- i have the four bulbs- 4 equalizers 6 ohm -- all installed -- sometimes the turn signal flashes "f-a-s-t-" i talked w/ chris from autolumination and he said to try 2 6ohm equalizers on each light-- one to turn sig - another equalizer to the third wire-- both connected to the ground wire. i have not tried that solution yet. rvette@usadatanet.net if you want to reply to me or this forum is fine -- i think a lot of us would like the answer!!! my taillites are stock as well-- left side yellow/ground brown wire- black wire---- right side green/ground-- brown wire-- black wire- on a 2000 vette ----any ways --- any help would be muchhhhhh appreciated!!!! thanks bob
14U2ENV,
I forgot to check it after I was finished so after I read your reply I went out to the garage and checked it.
After using the Emergency Flashers there were no codes present at all
No problem
You need to install one Load Equalizer in the wiring harness at each bulb.
R/H Side: Install one Equalizer between the "Dark Green" wire and the "Black" wire at each bulb (inboard and outboard). The "Dark Green" wire is the power wire that supplies power to the "Brake / Turn Signal" element in the bulb and the "Black" wire is ground.
The "Brown" wire is the power wire for the Tail Light element in the bulb so do not attach anything to the "Brown" wire.
L/H Side: Install one Equalizer between the "Yellow" wire and the "Black" wire at each bulb (inboard and outboard). The "Yellow" wire is the power wire that supplies power to the "Brake / Turn Signal" element in the bulb and the "Black" wire is ground.
The "Brown" wire on this side is the same as the R/H side. It is the power wire for the Tail Light element in the bulb so do not attach anything to the "Brown" wire.
I hope this helps If you need any more help just let me know
thankks so much-- i did exactly that and at first i got fast flashing w/ the turn sig. i then took off the blue clips that came w/ the kit -- i'm not a fan of those--- and sent them w/ the garbage truck -- i then installed wire nuts to the wires exactly how you described it the turn sig worked fine. i then tried my running lites - all worke fine- w/ the running lites on, i turned oin the turns--- fast-fast signals as i sterpped on the brake w/ the turns on fast- fast signals again. !!!! 4 ways work fine. went to bed wondering if all this was worth it. got up this am and tried it all again-- only to find out all is working fine except the left turn sig flashes fast w/ the brake applied. i e-mailed chris from autoluminatiuon-- he said to try and put a 6ohm equalizer on each line green/black and brown/ black. so we would have two equalizer on each socket. did not try that yet. glad to hear yours are working fine. any help greatly appreciated. don't want to give up thx again bob
Originally Posted by ben dover
The easiest way to fix this is wire your old bulbs (paint them black) in parallel with the LEDs, then the car thinks nothing changed.
-Chris
No you will not.
And when the bulbs burn out buy new replacement bulbs as it is cheaper, and apparently more reliable as not everyone is having luck with the load equalizers. When I purchase my LED's I will be using the old bulbs in line.
Hey Bendover how did you place the bulbs inline and on which wires. By any chance do you have pictures?
Originally Posted by JTS97Z28
No you will not.
Just finished wiring the "old bulbs" back in line w/ the leds. took the equalizers off and baought 4 tail light sockets-- wired them in-painted the bulbs black- so far works very well.. thanks for the advice oh 4 equalizers for sale-------cheap!
