Is there a reverse lock out on a M6 at higher speeds?
When going down the freeway and shifting into 5th gear, is there a lock out to reverse so I dont accidently put it in reverse instead of 5th?
There is a lockout on the MN6 to prevent accidental shifts into reverse. I wouldn't try to hard if I were you however. I've read a couple of stories about someone shifting very hard, or very fast and somehow overcome the lockout(I'm guessing just the sheer force alone). As I recall it happend on a track day. So its there, just not totally mistake proof.
Paul
Paul
Paul
Paul
In mine, even sitting dead stopped, it takes 'extra effort' to move it all the way over to find reverse. Have missed a few times and thought I was going to go backwards, only to be humbled by inching forward instead.
Received 19,457 Likes
'20-'21-'22-'23-'24
Reverse locks out at speeds over 3mph or so. When I got my clutch redone for the 3rd time, the reverse solenoid was stuck to lock out reverse (it fixed itself after driving 10 miles or so). I could get it in reverse but I had to push very hard. I don't think it is possible to shift it into reverse by accident as I had to use both hands to bypass the reverse lockout.
Originally Posted by LoneStarFRC
Talon90 is correct. It can be done. It will wind up trashing the reverse gear synchros, if not the gear itself. It takes a great deal of effort and pretty much has to be "slammed" into it, but it can be done.
Based on the effort it took me to get it into reverse when the solenoid had reverse locked out, I find it hard to believe you would ever hit reverse instead of 5th unless the solenoid was broken.
It will not trash the synchros, it is an electric solenoid that prevents the shifter from going into reverse. There is no way you can trash the synchros by forcing it in reverse if you are stopped.
I didn't think we were talking about when you are stopped. The original poster was asking about doing it on the highway. I'm betting that would trash the synchros.
Like I said earlier, kiss your synchros goodbye (maybe worse)
Received 8,961 Likes
Paul
Paul
Bill
The reverse lockout is a solenoid that forces the shifter to stay in the 5-6 gate. However, the solenoid works in conjunction with a spring that keeps the gate closed. If you force the shifter into 5th hard enough you will go into reverse since you will override the spring pressure. They did this so the owner could shift the car into reverse in case the solenoid failed. However, I accidentally did this on the way to work this morning. I was not speed shifting or speeding. I shifted to 5th at about 40 mph and hit reverse. You know when you do it since you hear a lot of grinding while the gears bump over each other. This is the first time it happened on my Z. I had it happen on my 97 several times including on the track. I took it to the dealer and they agreed to replace the switch and that is when they found the replacement operated exactly the same. They called me at work and said they wanted to show me so I went over and tried both of the switches and they acted just the same.
Bill
Bill
