Replacing starter with welded longtubes
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08
My car got starter issue.
Bill here on the forum has helped me alots to trace out the issue.
Look like it is either my starter selenoid losen wires or it is the starter itself.
This has happened couple times in the past. It took me couple turns to start the car. The starter did not make any click sound and then on the third or 4th turn, it would start the car but not this time.
Bill has showed me to jumper the TDR wires (red and purple) and still no click. If it's clicked, it would be my ignition cylinder ...
So I am planning to check the starter selenoid and maybe replace the starter. However, I got welded longtube to the off-road pipes and the X-pipe as well . Last year, when I upgraded the heads, it was really hard to drop them down to get enough space to losen all the heads' bolts. So I am not sure with all that, will there be enough room for me to replace the starter?
Thanks in advance!
-Mike
Thanks in advance!
-Mike
Former Vendor
Originally Posted by connecticut
usually not, you may be able to get away w/ a 13/15mm universal socket to squeeze past the tubes
So I can remove the starter without remove the longtubes?
-Mike
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Originally Posted by mike76002
Thanks,
-Mike
-Mike
I changed my starter earlier this spring. I couldn't even SEE the starter until I got the (FLP) header out of the way.
1 Post
Originally Posted by Y2Kvert4me
NFW. You will definitely have to pull the pass. side header.
Having to remove the passenger side header to access and replace the starter is very common. Also, as food for thought, you may even consider wrapping thermal wrap around the starter to protect it from the high temps of the header right next to it.
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
I've got to agree.
You might want to call John Page (972 417 7177) and get his imput = let us know the outcome.
Former Vendor
Mine is welded so if I wanna take it off completely, I will have to cut it.
Former Vendor
Originally Posted by Neablas
never understood why people did a complete weld ..
They told me weld is the only way with no leak!
I found out it was pain in the a$$ when upgrade heads and now starter.
I will bring it to a shop to add a flange before replace the starter.
Need to push and pop te get it start now
-Mike
Former Vendor
Originally Posted by AC54ME
Mike,
I've got to agree.
I've got to agree.
I will talk to Nate or Jason.
Thanks,
-Mike
St. Jude Donor '03
Now, I am mad at my muffler shop
-Mike
-Mike
Received 19,305 Likes
'20-'21-'22-'23-'24
Mike - good luck with the repair. I'd be mad at the muffler shop guy also - what a PITA. Nate at the Corvette Garage should be able to help you out.
