Help! Rear Hatch will not open
Passenger side of rear hatch will not release. It appears the latch on the drivers side is attempting to release. My remotes and hatch release button on the dash will not open the hatch. If you crank up the car the release button on the dash will open the hatch the remotes still will not work. At one time the remotes and release button on the dash would open the hatch when the car is on or off. What do I need to replace (how do I replace it) to correct the problem. Thanks
1 Post
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
You might start looking at connections.
Something is loose.
What audio mods have you done?
Have you added any electronics ?
