AC Delco AGM battery?
I've read that the 78P-7YR is the AC Delco AGM battery, however I can only find the 78-7YR...Is this actually an AGM battery? I read that the 78P-7YR was discontinued. Is this correct, and what is the part number for the Delco AGM that fits in the 'vette? Also, what chain stores sell AC Delco?
Thanks!
Thanks!
Never heard of a current AC Delco AGM battery. Your choices are either Napa/Exide Orbital or Optima. Optimas seem to be flakey for some, so I'd stick with the Napa/Exide Orbital.
Here you go:
http://198.208.187.182/internet/Vehi...e=18&part=2476
The 78-7YR is the correct replacement battery. here's a short history:
The 97-00 AC Delco batteries had a tendency to leak from the positive terminal. The panic to replace them was so widespread that even in..
2001, when the AGM battery was introduced, C5 owners were mistakenly told to replace them, even though this version was leak and vibration-proof (my 01 battery lasted 7 years).
In 2004, GM went with top-terminal batteries and AC Delco discontinued its AGM series, primarily because the absorbant glass mat design was and is (as Optima Red Tops) weakened severely by infrequent use or short-duration trips. Those who use AGM-style batteries must either drive often/far enough or connect a battery tender to the battery.
The 04-present AC Delco non-AGM batteries benefit from a redesigned case, which is significantly stronger than the 97-00 case. These Professional batteries carry a 50-month free-replacement warranty - best of them all), the remaining 34 months being a pro-rated warranty.
You can get them at Murray's Discount stores. I just bought one for my 01 and I fully expect it to last another 7 years.
I only drive mine 2-3 days a week (max), so a Red Top is not a good option. Looks like the Yellow Top is a better choice. Just annoyed because it only has a 2yr warranty, and costs $180...
Buying an expensive AGM battery is like buying super-expensive run-flat tires. The cost of feeling "safe" or "protected" is significant. Only you can decide if the extra money is worth it, but I can assure you that leaky 2004 and newer battery reports are very rare in this forum. Based upon this fact and my conversation with an AC Delco person, I felt that their latest battery is an excellent choice for most people.
Dave68...thanks for that history lesson...right on...I still have my AGM in my '01...strong as ever but I use the Battery Tender Plus from time to time when the 'Vette's gonna sit...I didn't know they discontinued them...I have had good luck with A/C Delco batteries since 1985...'cept their cheap AAs they sell at Menard's...shorter life than the Duracell or Energizers I'm used to...
Bill
Bill
New Delco Not an AGM
Good Luck
Originally Posted by Kamil D.
Red top or yellow top what’s batter?
If I have the car but don drive very often but I will still use a battery charger witch one should I buy?
If you are narrowing your choice to Optima Red or Yellow, you should know that the yellow is really made for other types of applications, it is a deep discharge battery, it has advantages for applications needing heavy electric capabilities, like huge stereo units, marine use, and anything that will sustain heavy discharging as a rule. The disadvantage is that it is more difficult to maintain a full charge, needs more powerful charging equipment, and has less start/charge cycles built into it than a more normal car start battery. It will work, but it puts an additional strain on the alt, and you will pay much more for it, and it will not last longer than a less expensive battery. The Red is more appropriate than the yellow for a normal car or even the vette. If you choose to use a battery maintainer on the redtop, you must make sure that you use one that specifically says that it will keep an AGM battery full charged, and has at least a 1.25 amp charge rate, and special circuitry for an AGM. Now I'm sure others have differing opinions on which is better and maybe some will post, but that is my opinion on the Red / Yellow decision. Ultimatly I would not choose either for my vette, because the AC Delco Pro is an excellant battery with a 50 month Free replacement, and the remainder of 7 yrs pro rata , and is less costly to buy. But I have no reason to say that a Red or yellow will not work, they just need some special handling to get the full potential out of them.
Good Luck
Bestvettever:
I agree with your thoughts regarding the Optima's & have come to the same conclusion: I'm going to give the new AC Delco's a shot. A local forum member has a 78H6YR for sale that's a month or two old..Been on a bettery tender...He's asking $80...Does that sound fair?
Fair Battery Price
Bestvettever:
Good Luck
