Will paint stripper ruin plastic?
Old 06-21-2008, 10:15 PM
1sickz51vette
1sickz51vette's Avatar
Default Will paint stripper ruin plastic?
Thinking about painting some plastic pieces to match the car, but if I want to remove the paint will it damage the plastic (black) finish underneath?
Old 06-21-2008, 10:28 PM
Mr.Bill
Mr.Bill's Avatar
Location: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I think in most cases it will damage the plastic. It can make the plastic soft and lose shape. I wouldn't do it.
Old 06-21-2008, 10:32 PM
1sickz51vette
I'm trying to paint the inserts on my wheels to match the car color...
Incase I dont like it though I want to be able to remove the paint without messing up the origional black plastic finish
Old 06-21-2008, 10:39 PM
10U 99
Support Corvetteforum!
10U 99's Avatar
St. Jude Donor '08-'09
YES !! it will melt plastic
Old 06-21-2008, 10:42 PM
yaknow
yaknow's Avatar
yes
Old 06-21-2008, 10:46 PM
dachevy
dachevy's Avatar
Yep, surely will, from personal experience, but not on my Corvette...
Old 06-21-2008, 10:50 PM
NEVERL8C5
NEVERL8C5's Avatar
Cut some vinyl contact shelving paper to fit and spray the color on it. Then place on the wheel inserts and if you dont like it peel off and throw away. Cheap and easy to remove. This is a little more work but at least you won't have to strip the paint.If the result is good mask and spray.Good luck.
Old 06-21-2008, 10:53 PM
madmatt9471
madmatt9471's Avatar
Location: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
It will damage the plastic!
So I will suggest you use paint thinner and just use it to wipe the paint off before it dries. If this is not acceptable then see if you can get a paint stripper that is plastic safe.
I did a quick search and found this:
http://www.chameleonproductsonline.c...etipsfaqs.html
A couple of other sites used the same Chameleon stripper too! Hope this helps
Thanks,Matt
Old 06-21-2008, 10:59 PM
olefam
olefam's Avatar
I just used a professional paint stripper on my fuel rail covers. NO PROBLEM AT ALL. Body shops use these products to remove paint from plastic car panels that need to be refinished.
If you wish to do this, go to an auto body shop supplier. Be prepared to pay some serious money for these chemicals. Explain what you are trying to do and listen to the experts advice.
I'm sure you can take it from there.
Glen
P.S. My freshly painted fuel rail covers turned out pretty good considering I'm an amateur.
Old 06-22-2008, 01:03 AM
dobewillie
dobewillie's Avatar
pretty sure you will have problems
Old 06-22-2008, 05:25 AM
1sickz51vette
Ahh great, I wish they just made different color inserts for these wheels already...
To Will paint stripper ruin plastic?
Quick Reply: Will paint stripper ruin plastic?
