Seat Memory and side bolsters....
Old 07-09-2008, 10:22 PM
ScottPurlee
ScottPurlee's Avatar
Default Seat Memory and side bolsters....
I have a 2000 convertable with 2 drivers side only seat seat issues.
1) The seat memory has stopped working properly - pressing the "1" or "2" (or both) only causes the seat to jump a bit forward. I can do this repeatedly and it will hop it's way foward. The side button for forward/back movement works fine.
2) The side bolsters stopped working. The 2 lumbar supports work fine.
I didn't see anything in my forum search.
I'll check the under seat connections, etc. Other than that are there any ideas?
Thanks!
Old 07-10-2008, 03:22 AM
ajg1915
Support Corvetteforum!
ajg1915's Avatar
St. Jude Donor '08
Thanks!
Check your DIC for codes ??
http://www.stengel.net/diccodes.htm
More than likely the memory problem is being caused by a bad door switch or the seat control module (located under the seat).
The side bolsters could be a bad pump, switch, hoses or leaky bags.
The problems are independent of each other.
Old 07-10-2008, 09:08 PM
ScottPurlee
To Seat Memory and side bolsters....
Quick Reply: Seat Memory and side bolsters....
