When Air Comes Out of All AC Vents - A How To Fix Write Up with Pics!
#42
I need to fix mine, now.
Awesome write up.
Awesome write up.
#44
I dug into mine today and found a vacuum line under the battery box completely broken in two. I put a slice on it and put it back together with zip ties (i tugged on them to make sure they were secure) but it's still blowing out all vents. Frustrating....
#45
Your best bet might to replace the line completely from the rear of the manifold to the valve in the fender and eliminate any of the old plastic line and old 90 elbows.
Thanks, Matt
#46
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
BC
#47
Nice write up, thank you.
I read it over and over but don't see a parts list that i need to get to do this.
Am i missing something?
I need to tackle this on my c5 vert soon as well.
#48
Re: Vacuum 'Block' (aka Solenoid)
Love this thread. Just read from start to finish.
My problem is that I'm getting NO VACUUM out to the RED vacuum line to the Heater side of the "Defrost/Heater" diaphragm. UGH.
Just got off the phone with Mark at VetteNuts.
Paid immediately via paypal.
But thought I'd give you a NICER picture of that "Vacuum Block"
Oh, on a 99 Coupe with the "CJ2" option, which is the "A/C Electronic) option.
The GM part number is : 52469694
Got that from the C5 Parts and price list that a fellow member posted in PDF format.
(afterthought) I've added the 'diagram' for this from my Factory Service Manual as well.
#49
Thanks,Matt
#50
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Here is a picture of the AIR BOX removed from the car:
MKIVBB (06-15-2016)
#51
Love the pix. Thanks.
Got a replacement part coming from Mark at VetteNuts!
Great Price, and verified shipped yesterday, the day I ordered it. YAY MARK!!!
#52
Using one of your pictures, Bill Curlee
The "Heater/Defrost" Door is controlled by the Vacuum Diaphragm.
The Diaphragm is a "THREE POSITION" type.
No Vacuum, it centers, and allows air to flow out BOTH the Defrost and Heat (foot) vents.
Depending on which MODE you place the Electronic Control in, either Defrost, or Heat (foot) vacuum is applied the desired side of that diaphragm, (Red or Yellow) by the Vacuum Solenoid.
Everything on mine works "EXCEPT" RED.... UGH.
And after all my searching, someone here recommended Mark at VetteNuts.
YAY.... Great Price.
I'll let you know if, (but I'm pretty sure it will) this fixes my problem.
#53
Great write up, and thanks a ton for taking the time! But is there any way you can label some of the pics maybe with an arrow or something pointing to the suspect vacuum line? My Z06 just started doing this today. Gonna tackle it this weekend. Thanks!
#54
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Art... Sounds like you either have a broken RED LINE or the controller isn't working for that vacuum solenoid can.
Keep your OLD Controller.. I would like to dissect it and see why it failed..
Bill
Bill
#55
I'm in the middle of doing this right now, but can't seem to find the vacuum supply line. Where in this picture is it supposed to be?
I removed my battery and battery tray to give more space, and I believe I found the end of the vacuum supply line that goes into the fenderwell, but it looks like is wrapped up in a big loom of wires that goes back towards the engine.
Am I lost here?
Am I lost here?
#56
Am I lost here?
Am I lost here?
#57
Am I lost here?
Am I lost here?
Ok, with a mirror and flashlight I finally saw the vacuum nipple on the back of the intake manifold, and low and behold - the right angle rubber fitting that was supposed to be on it was unplugged! I re-plugged it in, am cleaning under the battery (didn't see any signs of acid, but just doing some housekeeping cleaning the dirt/grime build up under there) and hopefully once I get the battery back in my problem will be solved. Fingers crossed!
Sounds like you should be in business once all is back together -
Let us know how it goes!
Thanks,Matt
#58
Everything worked great once I plugged the hose back into the MAP sensor on the back of the manifold. Glad it was something simple. No idea how that damn thing came off.
Thanks to all of you guys who posted the info and pics! Definitely made this a smooth deal.
#59
Contoller Solenoid.
I'll get it to you soon.
Right now dealing with open circuit on Intake Air Temp Sensor.
Tan lead to PCM... Open circuit. UGH.
