For track days & autocross - Should I convert to manual or stay automatic?
I have an '04 automatic coupe. I was discussing some transmission upgrade questions with some of the other members and I great advice about the transmission vendors to look into, but I got mixed reviews of whether I should keep it automatic or switch to manual for weekend track days and autocrossing.
So, whata think and why?
What is your % of tracking vs autocross? On an open track seems the M6 would be better,,where it would seem the A4 would have an edge on a tight autocross. Personally I like my M6,,but I'm old school,,even on the strip!!
For the most part On a a4 I would think shift it into 3rd and leave it. On tight/slowish parking lot auto cross coarse 2nd would be fine IMO.
IMO I would leave an auto vette alone and purchase a 6sp if you want a 6sp and transfer over all of your bolt ons that you can.
At least 90% of the folks I see at AX and Track events are manual (all brands). I've never driven an auto in either venue so can not give a comparison. I just can't see the auto working well on a road track but YMMV. On AX it would probably be ok. Most AX courses you shift to 2nd right away and leave it there the whole time.
I'd recommend you do some events with the auto (assuming you haven't already), talk to some folks at the track. Usually in AX events, once you meet a few folks, you can trade cars for "fun runs", maybe you'll get the opportunity to try a manual. If you don't like it...swap it out in the future.
If you keep your A4, it is possible to totally re-map the shifting points with one of the better tuning programs..Even the lowly LS1-Edit can do transmission map editing. This may be even more important if you have the tall geared rear and ratio..I have the shorter 3.15 differential, and wish it were even lower...Don't need top speed, need more grunt below 100!
I had mine completely remapped to extend the shift points way higher, even at light throttle. I got tired of it hitting 3rd at 20 some MPH, and lugging around at low RPM with slow response if you really needed to go quickly...
Now it it won't even get into 2nd until 28mph , and 3rd until 49mph. At wide open throttle, it will not shift until redline. The car is no MUCH more responsive and doesn't hunt gears at moderate speeds. Another thing, the shift tightness can also be programmed for less time as one band lets off and the band for the next gear engages.
Run with traction control switched off... the throttle seems to react faster, and the trans seem to shift a little faster too, but only the programmer guys know for sure! I wish we had real throttle cables instead of a computer driven servo motor for the throttle...Anybody ever put in a Camaro LS series intake and computer? It is a direct connection to the throttle pedal, no computer lag to hold you back...
Received 8,959 Likes
In an autocross you should be OK but on the track the automatic is a PIA. They never shift when you want them to shift. Either to late or to soon. The problem comes when braking for a turn and getting the transmission to down shift at the correct time. If it downshifts early you are still on the brakes, too late you are on the throttle and the downshift comes right at the correct time to spin you off the track. Then you get all the heat buildup in the tranny.
Bill
Bill
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
However, we now do have cars that can upshift and downshift with triptronic type transmissions that will put an experienced MN6 driver to shame on a track even with a novice driver behind the wheel. New Nissan GTR is one example along with all Formula 1 cars
Coming from someone with old school HPDEs experience, manual is the way to go if you want to be competitive. If you just want to have fun, there is nothing wrong with starting out with A4 at all but you will soon realize that manual is the way to go.
Had to hear your opinion on this one! Are you saying that just when I am getting decent wth my MN6 I should junk it? Just went to the road course last week for the first time,,,,wow that was fun! My current sig pic was shot there by SWR!
When's the next vette coming!
My new car will be out of the shop this coming Friday. Everytime I post something about the latest progress (all my friends hang out here) in C5 General, the thread gets locked. Not my loss
In tight turns I can hold in 2nd gear, as my tuning allows up to about 100mph before I'm close to redline. Straights into 3rd, but I'm experienced enough with my car to know when it to shift down to 2nd and load the car properly into the turn. You certainly DO NOT want the car to lurch with the downshift from 3-2 while in the turn. Back end can kick around on you. (I'm also running a Yank SY3500 tc)
I was a little worried too, until my first time with an instructor, who said that most guys starting out with manuals shift too much anyway, and that having an A4 with that mindset will preclude you from shifting only when needed.
An A4 is for drag racing and the MN6/MN12 are for auto-x and road racing. Its up to you what you want to do, but if I ever decided to do a lot more road racing I would just sell/trade my vert for another C5 w/a stick.
On a road course you MUST manually shift your A4. Downshift at the end of the brake zone, before turn in. Upshift as you accelerate past track out.
Other wise he A4 downshifts AFTER the corner, and unsettles your car.
Sounds like a good excuse to get a 2nd Vette.
