Doe's any brand of high test not have ethanol???
Did same to my '67 Jaguar XKE. Went into the garage one morning, and found gas all over the floor! All the plastic parts in the fuel system, and the SU carburator diaphrams had melted. I was not pleased. Fortunately, all the replacement parts (from Joe Curto) are friendly to the "new" gas, so problem was fixed in a few hours with miminal tools.
Location: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Sunoco GT100 race fuel in GA
http://www.sunocoinc.com/Site/Consum...ns/Georgia.htm
http://www.whitfieldoil.com/www/docs...p-racing-fuel-
VP race fuels
http://vpracingfuels.com/fuels_unleaded.asp
and Race Fuel Stations
VP race fuels
WOW....Thank you!!!!! I did try and search and had no luck so I really appreciate you giving me those links
I want to try the 100 octane and see if I can tell a diffrerence between that and what I have been using. It looks like the Sunoco product does not us the ethanol, is that the best choice??
Again Thank you,
Gonzo
Hi There:
Did a google on this subject.I was surprized that it went into effect in 1990.
MTBE started getting added to gasoline in a big way after the Clean Air Act of 1990 went into effect. Gasoline can contain as much as 10% to 15% MTBE.
The main problem with MTBE is that it is thought to be carcinogenic, and it mixes easily with water. If gasoline containing MTBE leaks from an underground tank at a gas station, it can get into groundwater and contaminate wells. Of course, MTBE isn't the only thing getting into the groundwater when a tank leaks -- so is gasoline and a host of other gasoline additives, but in recent years, MTBE has been singled out.
robsc501
robsc501
ethanol
In Md. the BP stations do not have any signs on the pumps that they contain ethanol. Now they got something called Invigorate. What ever the hell that is All the Sunoco's station that i visited in Md. have signs posting on every pump that there gas contains 10% ethanol. Sunoco lost me as a customer when they stopped selling 94 octane. abut 2 years ago here in Md. I'll will run out of gas first b/4 i put a drop of Sunoco in my tanks. Sunoco is a sell out
Ethanol is also more corrosive and eats away at metal components,but most late model cars have alloys that will tolerate it. I have a hard time understanding why anyone would use 87 or 89 octane in a vette though.........
Fuel may contain ( which almost all stations do) have UP TO 10% Etoh ( Ethanol ) WITHOUT posting signs legally.
Basically figure there IS Ethanol in every fuel unless the stations post a sign, NO Ethanol Added
Ethanol can come from many sources. Ethanol in US fuel is derived from corn to prop up the farm and corn subsidies. Not necessarily reduce emissions.
Ethanol used in Central and South America is derived from sugar cane
Here's how you can tell if there's ethanol in the fuel. Fill a container to a specific mark on a clear glass container then fill the rest with the fuel. The real gas will separate from the water but the ethanol will bind with the water and the "water level" will move up about 10%. I test periodically for my a/c to make sure it still all gas. I'm sure at some point (especially with the current administration) that all gas will have 10% at which time I'll have to resort to more expensive 100LL aviation fuel.
the product is named STARTRON ENZYME FUEL TREATMENT" it's pretty expensive per bottle but it's one of those things where a little goes a long way. it's an ounce per 20 gallon tankful. it works out to about $1/treatment. if you research the problems, i believe you'll agree it is something pretty necessary for pre mid 1990's vehicles.
