"Service Column Lock" meaasage 2000 manual
2000' manual. I have a "Service Column Lock" measage. I Reset , turned car off. Started car and messsage is back. I reset the message again and drove 30 miles with no problem. What could cause the message to display and the steering wheeel not locked?
DJ
I had the same problem on my 01 vert, I went with the column lock bypass module, so I have no worries!
http://www.corvettesofhouston.com/pr...products_id=54
this is what I used!! Best of Luck!
Fitt's Vette
Fitt's Vette
Start here http://forums.corvetteforum.com/c5-g...-question.html
Or with a search for posts by 8vette7 (username), he knows the CLB system inside and out.
Good luck
Good luck
Good luck
Good luck
We have all been there... Good luck and call Corvettes of Houston. $60 and you will be good to go.. Plus, make sure you have a GOOD battery! You need a min of 12.5 v to make the computer happy..
DJ
Received 19,472 Likes
'20-'21-'22-'23-'24
Good deal that you got it fixed. It's a problem that GM never really did solve - unfortunately. The column lock bypass is well worth the money and peace of mind.
