Changing front turn signal bulb
#41
I'm speculating here, but is it possible the brake air duct is larger on the Z06 than the base car? When I tried to displace it as shown in the video, it could only be pushed down enough to provide about half the clearance of the opening. I don't have particularly big hands, but I think anyone who could get their hand through, at least on a Z06, would need to have "itty-bitty" hands. So I shifted to removal of the black plastic cover and the hood support screw, which took very little time, and that made access to the light socket very easy.
tq
tq
#42
Front Blinker Light / DRL Change - Thanks for the LInk
Last edited by Diva Toy; 05-08-2016 at 09:58 PM. Reason: Clarified title for searches.
#44
Speaking from experience, the easiest way to swap the turn signal bulbs is from the top. My arms are far too large to squeeze into the tight spots. Remove headlight, swap bulbs, reinstall headlight. 10 minute job.
10 minute job for each side that is...
#45
If your hand won't fit, get your wife or that little kid who lives next door to do it. It's real quick and easy and you don't take anything apart, or get your arm crushed when the headlight closes on you.
OldBalz (10-31-2016)
#47
Junkman video for non Z06 C5's. It really is by far the easiest in my opinion. Nothing to remove, no tools, no jacking. Only thing I would add thats not in the video (I think) is to coat your wrist area with mineral oil, vaseline etc so you don't abrade your skin. Check it out, very easy! Best wishes!
#48
I just changed out my driver's side turn signal bulb going in through the brake duct hole earlier this morning. It took all of 5 minutes. Yes my hand got stuck for a few seconds but it was a quick and painless change. It was also the least expensive change.
#49
Geezuz, Joseph & Mary what a PITA THAT was. I had to take the tire off to get at two more bolts so I could get the panel right off. Then getting my arm in there......then getting that stupid tab squeezed.....even putting the bulb housing back in took me 25 tries. - What a headache I have.
I can't wait 'til the driver's side burns out.
#51
C5 front turn signal bulb replacement
Start the car. Raise the headlights. turn the headlight switch back one turn to keep the lights up. Shut off the car. Raise your hood. Remove the 3 screws on the black wind guard around your head light. Make sure you store the 3 screws securely to insure so you don't loose them. You now will be able to easily reach all of the bulbs associated with your running lights and turn signals. This is real easy. Remember that there is a release lever on the light bulb plug that needs to be pushed in to get the plug out of the light box. Slowly pull the bulb out of the plug and replace it with the new 3157 NA bulb. Test the directional signal to make sure it works. When it does reverse the process and move on. Shouldn't take more than 10 minutes. Good luck
#55
St. Jude Donor '15-'16-'17-‘18-'19-'20-'21-'22
Having skinny arms and a cool engine compartment certainly helped.
#58
I've gone for a two bulb approach, extraction from above and reinsertion via the brake duct. I could only get all glass bulbs, which are thicker at the connectors. The first one popped out of the connector during reinsertion and into the light unit! I just couldn't face removing the light so rammed the second bulb into its holder (which I think is the hardest part of the whole process) and got it into the light.
It all works and I can't hear it or see it I'll get it out when I fit the fixed unit .
