1998 horn issue
Old 11-27-2011, 08:02 PM
bobbyd123
1st Gear
bobbyd123's Avatar
Default 1998 horn issue
the horn suddenly sounded and would not stop while sitting parked in driveway........had to pull fuse to silence it......not sure if its an alarm issue or ground.......any ideas ???
Old 11-27-2011, 08:21 PM
damilleniumboy
damilleniumboy's Avatar
It's the bladder/switch inside the steering wheel behind the air bag that is old and it causes a contact, so your horn honks. To fix it you have to pull the steering wheel and replace the bladder/switch.
Quick Reply: 1998 horn issue
