Z06 Spring Cushion
Old 01-05-2013, 10:00 PM
randyfl
Support Corvetteforum!
randyfl's Avatar
Default Z06 Spring Cushion
I had my Z06 raised back up and it seams a little high. I believe C5 coup cushions were used. Are the Z06 and coup cushions the same?
Old 01-05-2013, 10:07 PM
dblerman
dblerman's Avatar
Not sure what "coup cushions" are. The only thing the mechanic should have done to raise the car was turn the ride height adjustment bolts a few turns. Most likely he just turned it too much for your preference.
Old 01-05-2013, 10:30 PM
randyfl
randyfl's Avatar
No, when I bought the car it was slammed. There were no adjusters (I called them cushions) in front. Since you cannot but just the adjusters he found some and installed them. They are adjusted as far as they can be to allow for a lowered stance. During my search I found some used springs Z06 and Coup springs. The Z06 adjusters seemed thinner The adjusters on the coup springs seemed to have a thicker Head / cushion. What I men by that is the portion that actually rests on the contact point.
Old 01-05-2013, 10:35 PM
damilleniumboy
damilleniumboy's Avatar
From the factory, the lowering bolts have about 1.5-2" of bushing, and you can cut the bushing part to lower the car more. Aftermarket lowering kits have a smaller bushing. You can raise the car or lower it by turning the bolts at the end of the leaf-spring which makes contact with the lower A-arm, and yes you can buy the lowering bolts by themself.
Old 01-05-2013, 10:36 PM
dblerman
dblerman's Avatar
oooh, you mean the bushing on the bolt. As far as I know, it should be the same bolt for Coupe and Z06. If the ones you were looking at were thinner they might have been cut by the previous owner or are aftermarket lowering bolts.
Old 01-05-2013, 10:39 PM
dblerman
dblerman's Avatar
Ahhh Jennifer Aniston beat me to it by 30 seconds haha.
Except I don't believe you can buy OEM lowering bolts by themselves, only aftermarket.
Old 01-05-2013, 10:41 PM
damilleniumboy
Well haha, and yes I forgot to add "aftermarket," to the post.
Old 01-05-2013, 10:48 PM
randyfl
randyfl's Avatar
Right, you cannot buy just the (factory) bushing. So all factory bushing are created equal right?
Old 01-05-2013, 10:51 PM
damilleniumboy
yes and yes. Aftermarket ones aren't expensive at all either.
http://www.ebay.com/itm/C5-Corvette-...2c0104&vxp=mtr
Old 01-05-2013, 10:57 PM
randyfl
randyfl's Avatar
Thank you all for your responses
To Z06 Spring Cushion
Quick Reply: Z06 Spring Cushion
